My PC has 3.8 Quad Core processor and 16 gigs of ram.
I have Time Warner Cable. I use to have a normal cable box from them, and used my PC as a DVR with the TV tuner card, it worked great. The guide even came up on my PC in WMC also. But I moved, and gave up the cable box. I thought I would still be able to have cable going through my pc, but its only finding 9 channels, a few of them are dead, and 2 are in spanish. When I plug the cable wire directly to my TV, the cable works just fine. Any help would be great, thank you. (I would just watch TV with the cable wire plugged directly into the TV, but I want to use my PC as a DVR and use WMC's guide.)
