AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Seeking speaker mount fittings (bracket) for Pioneer PDP-S40U speaker
post #1 of 3
Hi All,
I have a Pioneer PDP-5070-PU tv with a Pioneer PDP-S40U bar speaker. Unfortunately, after 2 moves in 1 year we can't find the under-TV mounting fittings for the speaker.
Would anyone happen to know where I can buy a set?
Thanks in advance!
Edited by overhear - 2/21/13 at 12:56pm
post #2 of 3
I presume the TV is a Pioneer not a Panasonic, if so you might try calling Pioneer's Parts and Service department:
1.800.228.7221
post #3 of 3
Oops -- you're right, it is a Pioneer. I must have been oxygen deprived from trying to get the model number from behind the wall-mounted set!
Thanks for the suggestion. I did call Pioneer. The good news is that they do have the brackets available. The bad news is that the full set is almost $80 + shipping. Somehow I didn't think they would be charging so much for those little brackets for a discontinued model.
I think I'll sleep on it.
