AVS › AVS Forum › Video Components › Home Theater Computers › Is the Define XL case discontinued ??? (WTF are people going to use to build a tower server now ?? )
post #1 of 12
http://www.newegg.com/Product/Product.aspx?Item=N82E16811352017
This item is currently out of stock and it may or may not be restocked.
you guessed it....
post #2 of 12
post #3 of 12
Where you buy ?
post #4 of 12
post #5 of 12
post #6 of 12
http://www.anandtech.com/show/6764/fractal-design-define-xl-r2-case-review-maybe-we-can-have-it-all
Google really is an amazing invention.
You should try it sometime.
post #7 of 12
You can find it here: http://lmgtfy.com/?q=fractal+define+xl
And, no, I can sell you my Antec 300 Illusion if you want.
post #8 of 12
The NZXT Source 210 is an underrated server case.
post #9 of 12
I used the NZXT Source 210 case for a budget build a little over a year ago for someone who wanted the white w/black theme, and there are quite a bit of cooling options, as well as the ability to house 8 Hdd's. I will say the 210 was a much better case than I expected it to be. However, I would say if you were going to pack it full off drives though, you should consider the Source 220, that has a mesh front for better airflow.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146083
I almost considered getting the 220 for my own server, before I finally settled on a Rosewill Server case.
post #10 of 12
I was looking for an XL also (not R2). Since I couldn't find it, I went with the Define R4.
post #11 of 12
Try these guys. one of my favorite local stores. They list the XL but if it's been discontinued they won't be able to order it. On the other hand they might have one in stock.
http://www.centralcomputers.com/commerce/catalog/spcategory.jsp?category_id=1067&mfgId=2338&czuid=1361575946578
post #12 of 12
Here's a nice list of server cases courtesy of the unRAID forums:
http://lime-technology.com/forum/index.php?topic=17799.0
