Hello, I need an advice with choosing speakers.
I have AV Receiver Denon 1802, rated 80W with 8ohm per channel, it accepts speakers with impedance from 6 ohms.
I will use them for music and movies, 50:50 and will buy 5.0/5.1 system. I will maybe update receiver too later
Room is small (2m x 3.4m)
Because I am limited in size of speakers, they have to be no more then 20cm in depth, or depth up to 25-26cm but limited to 17-18cm in width. And because speakers will be 1cm from wall, I need front bassreflex, or closed speakers
Situation on picture
http://img687.imageshack.us/img687/6568/repros.png
After searching I found these speakers on market. All are from different sellers so it is not possible to compare them, and only QAcoustics is possible to borrow for home listening.
Variant A
20cm less in depth
- Q Acoustics 2010, 140€/pair, 6ohm
- Q Acoustics 2010i, 180€/pair, 6ohm
Variant B
longer in depth but width is less then 17cm
- Tannoy Mercury V1, 200€/pair, 8ohm
- KEF C3, 240€/pair, 8ohm
I would buy Q Accoustics because I found very good reviews on them. But I am afraid if I buy newer AV Recevier, I will be limited to only ones that support 6ohm speakers.
Which one would you recommend me?
I was personally decided for Tannoy but they will be very close to fit. I found Q Accoustics later but they are closed and 6 ohms.
Variant A
20cm less in depth
Variant B
But height can be up to 45cm, and more if I set shelf with speakers lower. problem is combination of width and depth..
