AVS › AVS Forum › Audio › Speakers › Watching 7.1 movies on a 5.1 setup
post #1 of 7
Do you miss a lot of the effect? I know you don't miss any actual sound but what about the "effect"?
post #2 of 7
Since one pair of surrounds cannot be in two places at the same time (at your sides and behind you, simultaneously), the main things you will miss are wrap-around envelopment and rear-vs-side directionality in the surround field.
However, that isn't an excuse to shoe-horn a 7.1 set-up into a situation where it can't be done properly, like if your seating is at or near the back wall. I would rather have a properly done 5.1 set-up than a poorly done 7.1 layout.
post #3 of 7
I ran 7.1 for a while and it did provide a more "enveloping" sound. I thought I'd miss it when I went back to 5.1...but I don't.
post #4 of 7
How could you not miss 7.1! Why did you go back to 5.1? Change in room lay out?
post #5 of 7
The placement of the ADPs was constrained by the way the wall opens out on the left side of the room. The pillar was the only place I could really mount the left speaker. As a result, it placed the ADPs just slightly forward of my seating position. I didn't want to move the seats any farther forward because they would have been a bit too close to the screen for my liking. When one of the ADPs developed a problem with one of its midrange drivers, I decided to sell off the speakers "as is" rather than sink a couple hundred into replacing the driver.
7.1 was pretty cool but, honestly, I don't miss it. I get very satisfying sound from my 5.1 set-up. biggrin.gif
post #6 of 7
I agree. I tried to shove 7.1 into my room and in the end went back to a proper 5.1 set up.
post #7 of 7
So how many feet behind the seating area is recommended for the rear speakers?
  Back to Forum: Speakers
