I've spent countless months searching to try to find a solution to my unique problem and now i'm hoping starting a thread will help.
I am using an ASUS Xonar D2 soundcard hooked up to my receiver using analog 8 channel multi output. All 8 speakers would great in the windows tests, the surround sound is amazing in games, but i cannot get movies to work in 7.1. They always play in 5.1 regardless of input format or program used. For example, when I watch star wars ep3 (which is supposedly 6.1) in either VLC or MPC-HC i only get 5.1. I've tried all sorts of filters (ffdshow, etc) to try to get 7.1 via dolby prologic IIx, but it never makes a difference. The only way I can get 7.1 to play is using dolby PLIIx in the asus xonar audio driver panel and this only works for stereo input. Does anyone have a way to automatically upmix or surround fill any source material into 7.1?
