Originally Posted by
goMO
the screen looks better than ever! my plasma is almost 8 years old, so it was due. I used the microfiber every once in a while for a specific smudge, but this seemed like a well earned wash!
You can also use a scent-free Swifter Sweeper refill for weekly dustings. No chemicals, dry, and it picks up all of the dust very easily and leaves absolutely nothing behind on the panel. I do that weekly on mine and only use the distilled water/microfiber cloth as needed (which isn't very often).
