They did a piss-poor job at cleaning the mirror and there seems to be some smudging on it.
I discovered this after seeing a cobweb in the center on the screen through the ports.
Shortly after I discovered the cobwebs, the screen fogged up pretty bad between the Fresnel and lenticular screen when I left windows open on a cold and humid day with the weather in Florida on a cooling trend last week.
This weekend I'm going to take this project on myself. I know the basics of the project like using Monster screen cleaner and a microfiber cloth and have the manual to tell me how to get the screen off.
Should I spray the mirror if it is bad or just spray the cloth?
Which direction do I wipe? (With what motion)
Should I take the screen apart and clean between the lenses? Fog adheres to dirt
Edited by AnthonyB - 2/22/13 at 2:08pm
