It's called blackout EZ and it's basically the best thing I've ever seen to COMPLETELY black out a window. Really good if you're looking to totally control the room light in a theater with windows during the day. It is essentially a vinyl sheet that you cut to size and then fasten to the edges of your window to totally eliminate any light whatsoever from entering the room through the window. Around $25 for smaller windows and $35 for larger windows and you can get it in custom sizes if you need to cover a sliding glass door etc. I posted about this in the "general home theater" section but it applies here to so I'm cross posting here for some more visibility.
Prior Post:
Window_Treatment
Website:
http://www.blackoutez.com/
And Some amazon reviews:
http://www.amazon.com/Blackout-EZ-Window-Cover-Large/dp/B006S65GAE
It'd be interesting to see if people had success with this in a theater that has a window that has given them problems in terms of light leakage
Edited by MikeK614 - 2/22/13 at 5:45pm
Prior Post:
Window_Treatment
Website:
