AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Samsung 55ES7000 - voice and motion control dimmed out
post #1 of 4
Hi,
i purchased a Samsung 55ES7000 but when i navigate to the menus and try to enable voice and motion control then the TV says that "This function isn't available".
I remember that at the very first setup it asked if i wanted to enable or disable the feature, i chose disable.
How can i enable it?
Thanks in advance
post #2 of 4
Originally Posted by elelont2 View Post
Hi,
Thanks in advance
Voice and gesture control are on ES7500 and above models. The ES7000 doesn't have these features.
post #3 of 4
I don't think this is true. I read from various websites that the features are available. Also, the user manual says that it is possible.
e.g. http://www.samsung.com/uk/consumer/tv-audio-video/television/led-tv/UE40ES7000UXXU says that it is available...
Something else is wrong...
post #4 of 4
Sorry, I was referring to US models.
have you considerd calling Samsung customer support with your problem?
