AVS › AVS Forum › Home Entertainment & Theater Builder › General Home Theater & Media/Game Rooms › No Luck with TV stand, please help
post #1 of 4
I'm really having a hard time finding a quality TV stand to meet my needs. Here is what I'm looking for:
*Maximum Height of 19"
*Maximum width of 60" (preferably closer to 50")
*Enough space for 6 components, including AVR
*Solid quality wood
*Won't rattle from speakers/sub
Everything I find is either too wide or too high. If anyone can point me in the right direction, that would be greatly appreciated.
Best Regards
post #2 of 4
You may want to think about looking at one of those hall storage benches tha has places for baskets underneath the seating area. Most of those tend to run about the 18-20 inch seating height, scrap the baskets (or use them for storage elsewhere in the house). It should be pretty sturdy since the original purpose is for seating and all.
post #3 of 4
Thanks for the response Padre. I discussed my needs with a local carpenter. He is going to build me exactly what I want. I'm confident it's going to work out great.
post #4 of 4
Good deal! Sounds like you will get exactly what you are wanting as well as supporting your local economy!! Post up some pics when you get it done and set up at your house if you don't mind!
