AVS › AVS Forum › Audio › Speakers › I am looking a larger internal computer speaker mounts inside a PC
post #1 of 4
http://www.atlantisgadgets.com/index.php?main_page=product_info&cPath=5_10&products_id=106
the above speaker is mounted inside a PC with that single wire (+ ve & -ve) to the motherboard
from the above link, I have a few questions:
1) is it really stereo?
2) can I get a bigger internal speaker w/ better sound quality ? If not, can you buy a single speaker and solder the wire yourself ? Also, how big of the speaker can the load to the motherboard handle?
post #2 of 4
I would ask over at Tom's Hardware forums.
fyi, the speaker is responsible for the beeps and noises from start up and things like that, nothing more. It's not stereo.
post #3 of 4
The sound quality from the internal speaker is not stereo and you can't do that; not gonna work..
You need to get a pair of external powered speakers and plug then into the audio output jack on the computer.
Check out the Audioebgine 2 speakers or the Creative Labs T12 speakers.
post #4 of 4
the creative labs T20 is 28W for about $100, but for $150, it's 32W, so I'm not going to pay $50 for 4 more watt. But the T12 is too micky mouse
what about Creative Lab SBX20, is it any good? If not, is there anything better than that, i.e., a tower of integrated speakers?
As they are all made in China, are they TRULY magnetic shielded?
any other high end brand name besides Audio Engine? Especially a pair of satellite speaker that can mount on the side of a wooden rack?
Edited by happy hopping - 2/24/13 at 1:14am
  Back to Forum: Speakers
