AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Having an issue with my Onkyo TX-NR809 and Video.
post #1 of 2
When watching movies on my HTPC and using HDMI through the receiver, once I maximize to full screen the entire screen will shift about an inch to the left cutting off the left side and leaving a black bar on the right side. It did not do this with the Onkyo 509 that I replaced so it is an issue with the 809. Is there a setting I should look for or would this be a hardware issue?
Gear mentioned in this thread:
post #2 of 2
If I switch from the PC input to another input and back again it will display correctly until I enter full screen again.
