I have several sources hooked up to a Denon 1913 receiver which is right now outputting to a 1080P LED TV (non 3D). I want to add a 1080P 3D projector to the setup. If I added a 1x2 hdmi splitter to the setup like this =
Sources > Denon 1913 > 1x2 hdmi splitter > (output to LED TV and projector)
If I used both displays at the same time I know I'll run into issues with lowest common denominator since the LED TV has no 3D. But if I used the projector with the LED TV turned off, I should be okay right? I don't plan on ever using both displays at once. Thanks!
