AVS › AVS Forum › Home Entertainment & Theater Builder › General Home Theater & Media/Game Rooms › Newbie-looking for information about HDMI vs. CAT 5
post #1 of 9
Hi All-
I am just trying to replace my old projector and I'm getting outlandish quotes because my old projector was not HDMI and the newer ones require HDMI cables. Geek Squad is quoting me $400 for a 39.2 m (Audioquest Cinnamon) and another $100 to run it. I know there are cheaper cables out there, but he is saying that anything in the walls, he would put a better cable in.
Another guy said that for longer distances between projector and the equipment a CAT 5 would be better (B-320-1CAT-HDIRW). Can anyone enlighten me on this subject?
Also, how hard is it to program a URC MX880? The guy told me it would take 4 hours to program! We just have lights and the usual home theatre setup. Any help is appreciated. Thanks!
post #2 of 9
Originally Posted by azs872 View Post
Hi All-
What cables do you have now? Regardless, you don't need a $400 cable, and I wouldn't trust any HDMI cable at 40m without external assistance anyway. But do you really have a 40m run? Assuming you have component video run now, you can convert one of those coax cable to carry HDMI with a HDMI-over-coax device. (don't know if there are any that support 3D if that's important to you).
If you've got a cat5e cable there, or plan to run one, the HDBaseT single-cable solutions are the way to go. Monoprice has a set for $200 - many dealer-installed brands are available as well in the $400-600 range. There are other solutions such as the SnapAV one you mentioned, but the HDBaseT products will have the most features for the money...
It's not hard if you have the software. But you don't, and they won't give it to you. 4 hours feels like a long time (at a per hour labor rate) for a simple setup, it's not like they're starting from scratch. That may just be their standard charge for programming - may be negotiable...
Jeff
post #3 of 9
Hi Jeff
Thanks for replying to my post, but you are really speaking Greek to me. Right now, there are no cables at all. The HDBaseT single cable you are talking about, is that the one I indicated? I think that is a CAT 5 cable that he is planning on running. Or is it the SNAQP AV? The cable goes from the ceiling across to a utility room and then down to where the equipment is and he estimated 40 feet to be on the safe side.
As for the remote, If I buy the remote, it doesn't come with the software?
post #4 of 9
Hi Jeff
You said "replace the projector". Is it not going in the same place as the old one? There's certainly wiring to your current projector... If you're mounting it in a new location, then you'll want to run a number off cables (since running 3 won't be any more difficult than one).
Both of those solutions run over a single cat5e cable. If you're running cable anyway, run two or three of them...
No, not with URC remotes. I will refrain from further characterizations about that fact. mad.gif
Jeff
post #5 of 9
Hi Jeff
OK Jeff. The old projector is a Sharp XV-Z2000. It is mounted in the ceiling. There is an electrical plug in the ceiling for the power and then 3 other cords for the color, I think. Then there is a 3 prong cord (maybe that is the power cord). I can't tell because they are all coming out of the ceiling.
I just want to know whether it's better to have HDMI or whatever cable for the long run. OK it's an Audioquest Cinnamon 39.4" platinum white HDMI cable that Geek Squad is offering to run versus whatever cable the other guy wants to run. Still unclear what kind of cable that is.
post #6 of 9
40' (feet!) is still a long run for HDMI. I would recommend a Redmere cable over a super-expensive non-compensating cable for that length. If they are going to run cables anyway, an HDMI Redmere cable along with 2-3 cat5e/cat6 wires would be my suggestion.
post #7 of 9
Here's my $.02...
Go to Amazon and spend under $20 for 40' HDMI cable.. run on the floor and try it. If it works, great, just saved yourself a couple hundred bucks. If it doesn't, keep or send it back for credit. I've bought several 15' (cheapest found on Amazon [Link Depot]-- under $5 each) HDMI cables recently and they work just as well as the 1" multiple shielded ones I 'wasted' money on years ago.
http://www.amazon.com/s/ref=nb_sb_ss_i_0_6/185-5047868-0839217?url=search-alias%3Daps&field-keywords=hdmi+cable&sprefix=hdmi+c%2Caps%2C139#/ref=sr_kk_3?rh=i%3Aaps%2Ck%3Ahdmi+cable+50+ft&keywords=hdmi+cable+50+ft&ie=UTF8&qid=1362008422
It's a no-brainer. I've finally learned to ALWAYS check Amazon first.. another recent win is replacement bronze door handles about 1/3 of what the box stores charge. Nice iPod and iPhone cases for $3 each.
Edited by Jasman - 2/27/13 at 4:05pm
post #8 of 9
Unless you're running it yourself, you're at the mercy of the installer. Most installers won't run the cable you supply, but it doesn't hurt to ask.
For a 40' run, I wouldn't go super cheap. Use a Blue Jeans cable, or a Monoprice Red mere, if buying yourself.
Like Jeff said, run a few category cables too and leave them unterminated, for future use.
Don't run your PJ power cord in the wall. Add an outlet in the ceiling.
Figure out which way the joists run in the ceiling. It may be super easy to run new cables yourself, from the adjacent utility room. If it is very simple, you can probably hold off on the extra runs of category cable, and add them later if you need them.
post #9 of 9
Cat 5 or 6 would be easier to run, then use an HDMI Balun like the Atlona HDBaseT Balun, they're pricey but pretty bullet proof
