AVS › AVS Forum › HDTV › HDTV Technical › Newnan, GA antenna help.
post #1 of 7
So last week I finally made the decision to go OTA and ditch Satellite after 12 years. To test it out I bought a basic indoor rabbit ears antenna and was surprised at how well they worked. But is very sensitive to weather. So I want to get a more robust antenna (and anything else recommended) to improve the performance. I will use the existing cabling in the house from the satellite and likely will mount it outdoors near the existing splitter. This may have to be replaced. I want to feed signal to 4 TVs. Below is my TVFool data.
I was thinking about the Wingard Freeview. I am 30-35 miles from most of my local stations that I care about. How well would this work? Would it be good to get a signal amplifier? What am I not thinking about?
http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d1dda4a08f54979
post #2 of 7
Get one of these: http://www.amazon.com/RCA-ANT751R-Outdoor-Optimized-Reception/dp/B0024R4B5C
It should work very well outdoors.
Avoid any antenna with an amplifier with your very strong signals. The amp would likely overload and block many of your stations.
John
post #3 of 7
Looking at the chart, most of the stations come from the 1 - 40 degree direction. Now the question is; is WJSP important on RF 23. It's a PBS stations that carries World & a PBS Kids channel on the subchannels. I wouldn't worry about WJSP's translator on RF 13, as it's only 140 watts to the west, & requires a pre-amp for that station. It might be possible to pick it up off the back side, but results vary. Also, if you can't pick up WSB-TV on RF 39 from the main Atlanta tower farm area, then you'll need an antenna pointed at 267 degrees to pick up WSB-TV's translator on RF 17, which is closer to you than RF 39 is. Regardless of antenna, you need one with VHF-Hi, as you have 2 VHF stations in the Atlanta market. I would actually suggest either the Winegard HD7694 or Antennacraft HBU22 or 33 before I'd recommend the Winegard Freevision FV-HD30, or any 2 bay antenna. Since you're more than 30 miles from most of your stations, You want an antenna that has a bit more gain than the Freevision FVHD30.
post #4 of 7
Please add a location to the title of ALL antenna help threads. See my edit.
post #5 of 7
Thanks for all the input...great info.
post #6 of 7
post #7 of 7
Also, any recommendation on a mount for the Antennacraft HBU33 for roof/attic mounting?
  Back to Forum: HDTV Technical
