I have tried finding more specific information and have not been able to come to a specific answer. I apologize if this is already answered in a previous thread.
I bought the Onkyo HT-3300 2 years ago. It comes with the HT-R380 Receiver and the HTP-380 speaker package. The main complain I heard about this HTIB was its passive subwoofer. However, for me, this set delivers a lot of bass for my apartment. In efforts not to disturb my neighbor downstairs at night, I usually try to turn the Subwoofer and Bass settings to -12db and -8db respectively. I still get some vibrating bass, but I do agree it doesn't sound deep.
The 5 speaker system is a single full range driver, but I believe it lacks clarity, crisp sound and more and more this gets more annoying. Also, the dialogue coming from the center speaker is not good at moderate volume level, so I have tried increasing it by +2db and lower my front LR to -2 db, rear at 0db, and increasing the volume. It helps but still bluray movie sounds are not great. The Bose HTIB at best buy sounds amazing by comparison.
More to the point, I am ok with my receiver as it currently has all the features I need. I read that replacing the speakers can go a long way, and my budget is tight, and I am still in an apartment. I looked into the Monoprice 9723 5.1 which according to CNET perform as good as the Energy Takeclassic 5.1. To my understanding they would be a huge upgrade, but I am not sure if they are compatible with my receiver. I don't want to damage either the speakers or the receivers. Also, my receiver is for a passive subwoofer, and the monoprice/Energy are active so I thought about leaving my current subwoofer in place and replace center, front and rear only.
The specs for the receiver are as follow:
All channels: 110 watts minimum continuous power per channel, 6 ohms; Dynamic power 160 w (3 ohms front), 125 W (4 ohms front), 85 w (8 ohms front). Frequency response: 20 hz - 50 KHz/+1 db. Speaker impedance 6 to 16 ohms.
The specs for the speakers:
Impedance 8 ohms, 115hz - 20 Kh; maximum input power 100 w, recommended amplifier power 20w - 100w; sensitivity 89db.
Any help/comment is appreciated. Thanks.
