I'm in the process of wiring a new home and have a question about both 'quality' of speaker wire and 'how' to wire. The essence of the question is this. I'm going to be using a centralized rack that includes Sonos Amps (or similar) running to multiple zones. Some of these zones will have four speakers in a single room (e.g. kitchen), so two left speakers and two right. The length of the wire running from the amp to these speakers is probably 70-80 feet once you go up/down/sideways. If that's the case, how should I wire rooms like this.
Option 1: run a +/- wire to each speaker individually (so eight wires going all the way back to the amp, two wires on each L/R, +/- terminal.
Option 2: run a +/- wire to the first right hand speaker and then run another 10 foot wire to the next right hand speaker. Do the same for L
Then to make this more complicated (which is why I'm very confused), what gauge wire would I need in each Option and should the speakers be wired in Series or Parallel.
I'm asking this in part becasue I just looked at the wiring the builder put in and it is wired as 16/4 CL2 to the room (about 75 feet), then split to the right hand speaker and left hand speaker, then another 10 foot wires each to the other right and left hand speakers.
I have the same situation in several other rooms that are far from the central rack.
Would love some advice as drywall going up soon.
