AVS › AVS Forum › Audio › Speakers › Want to match center and surrounds to my DefTech Mythos Ones.
post #1 of 3
Hi all. I'm new to the forum! I have a pair of DefTech Mythos Ones I'd like to use as the foundation of a 5.1 home theater. Room is 14 x 15 x 8' and is located in a finished basement. I have the DefTech Prosub 800, which seems like plenty of sub, given the size of the room. I'm running this through a Denon 1909 AVR, which I plan on upgrading soon due to lack of 3D capability, and Epson 5010 projector. I was debating between the Mythos Seven and the Nine for the center channel and the Gem and the Gem XL for the surrounds. Keep in mind I plan on installing sound panels to optimize acoustics. So could I get away with the Mythos Seven with Gem surrounds, or should I go all in with the Nine and Gem XLs? Or are there other center and surround options I'm not considering? Any feedback is greatly appreciated.
Adam
post #2 of 3
After talking to DefTech, they recommend the Mythos Nine center with the Gem XL surrounds. But that is what I would expect them to say in recommending the better, more expensive speakers. They did say the Prosub 800 should be plenty for that size room. Any thoughts?
post #3 of 3
HT usually means you should sink your money into your center and your sub. You are happy with your sub...so go with the better center.
Just a rule of thumb that can be broken 10 ways but:
HT= Center and Sub (Most important)
Music 2.0 = L/R (sometimes sub depending on how low your L/R can go)
Mix HT / Music - Front sound stage L/C/R and Sub
HT + Multichannel sound = All are important
Again, exceptions to every rule like Phantom Center etc etc...but it is a decent rule of thumb to go by.
Also, you normally should stay within same family / brand of your front sound stage...
  Back to Forum: Speakers
