AVS › AVS Forum › Display Devices › Screens › DIY Screen Section › Replacing an SMX AT type screen
post #1 of 9
Hey guys, just trying to get an idea of the latest and greatest material for an AT screen setup. I bought some SMX material about 6 years ago and now i'm faced with replacing the material with new material due to damage to my SMX screen.
I was using a Mit DLP in a light controled room, the mits was the 4000 model, it sold for about $1,100 back when i purchased it.
The frame is 100"X42", its a CIH setup with a dual prism CAVX lens....
Dont even ask about the damage or i may just start crying :0)
post #2 of 9
SMX is a fairly higher gain AT material. As such, you should consider using a White Milliskin Spandex overlaid Light Silver Milliskin.
Both are easily obtainable via Spandex World at just $9.00 per yard.
The Spandex source links:
http://spandexworld.com/c3/catalog/product/5954
http://spandexworld.com/c3/catalog/product/795
A recent "White over Light Silver" Spandex Screen project link:
http://www.avsforum.com/t/1458217/a-135-diagonal-2-35-1-white-milliskin-over-light-silver-milliskin-spandex-screen-build#post_22991782
post #3 of 9
Looks like things have gotten cheaper over the years.
So the matte white goes over the silver ? What are your thoughts of the acoustic pass through.....
post #4 of 9
Excellent performance for the price using the suggested type of Spandex. I wish I had more specific figures and expert testimony to quote, but as of now the only testing that has been done has revolved around the thicker "Moleskin" material.
post #5 of 9
So, what were you guys using as AT material before spandex. Are any screen manufactures selling material ?
I will probably go with spandex, but just weighing options
post #6 of 9
You have the Seymour XD Centerstage. You can buy the material and build your own screen.
post #7 of 9
Depending on how bad the damage is, you might try using the SMX as a backer material for milliskin spandex.
post #8 of 9
I have to start from scratch, the screen is done, sadly enough.
post #9 of 9
I emailed Chris and he sent out a sample. I found the price for my 100"x 42" to be very reasable, about half the cost of my original SMX material.......
  Back to Forum: DIY Screen Section
