I have been getting the itch to do a DIY build, and was just browsing Partsexpress. I am completely new to the DIY from the ground up process so hoping I can get some help and some constructive criticism. But here is what I found, I came Across some budget friendly drivers that look like they could pair well together. They have the $9 Aura NS6-255-8A woofers. I was thinking 2 of those per speaker paired with the Vifa XT25SC90-04 ring radiator.
http://www.parts-express.com/pe/showdetl.cfm?partnumber=299-030
http://www.parts-express.com/pe/showdetl.cfm?partnumber=264-1014
The woofers look to be a little more efficient and if I double them up, There would a be a greater difference between outputs of the woofers and the tweeters. So I was thinking of maybe doing a 2.5-way set-up. Vifa on highpass, one Aura for lowpass, and the other running lowpass, but at a lower crossover point like 200hz. Would that be a good way to combat the combined efficiency of both woofers to better match with the Vifa? Both drivers seem to have plenty of range so I will be able to play around with crossover points. I hope this is making some sense. Just an idea that I have been playing around with since last night.
I have yet to model out an enclosure for the the Auras but I wanted to run the idea by some people with a little more experience. Don't want to waste any time if my idea is a burning pile of..well you know.
Thanks in advance for any and all help.
Todd
Todd
