AVS › AVS Forum › Video Components › Home Theater Computers › New Custom Assassin HTPC Build
post #1 of 14
Trying to share a few of the more unique builds that we are doing.
YouTube video at the bottom.
http://assassinhtpcblog.com/?p=356
Edited by assassin - 2/25/13 at 2:00pm
post #2 of 14
Cool looking case. The front LCD is very slick. Nice work.
What theme was that for WMC ? I can't tell if the red streaking I was seeing was odd camera behavior or a theme.
You should embed a few pictures in this thread.
You mentioned more than one build. What else ?? Or did I miss something?
post #3 of 14
I will. Posted from work while on lunch and ran out of time.
post #4 of 14
Added a few pics.
post #5 of 14
you took away the video lol....
I thought that was cool.
post #6 of 14
Can you toggle that display on/off so it's not blinding you while watching a movie?
post #7 of 14
Its at my blog. Still posted.
post #8 of 14
I had the same thought. Cool for sure it is. But if your see it instead of the movie it is distracting
A "mute" for the display would be cool.
Overall I like the build.
Basic parts but cool build. What exact parts did you use. I think I spy a CX430 and possible an Matx H77 Asrock ??
post #9 of 14
No, you cannot with this particular case.
post #10 of 14
Still pretty cool
First time using that case ??
Thoughts?
post #11 of 14
I've got a different Moneual case, and while I ended up disconnecting the display on it (it was a neat idea, that in practice, turned out to be much, much more trouble than it was worth and the touchscreen aspect of it was utterly useless), I seem to recall something in the iMon drivers to dim the display while playback is on. It stays on, but just darkens a lot more. Of course, I always ran it with a black theme, so the darker image was pretty unnoticeable to me while watching anything.
post #12 of 14
The case used is a Moneual MonCaso 972, which boasts a nice 7" touchscreen, built in to a case that is roughly the size of the Silverstone LC17, or our Premium Deluxe, cases. The dimensions are 17.0"(W) X 18.5"(D) X 6.75"(H), which could make it fit nicely into someone's Home Theater Rack, or Entertainment system in their living room, and the touchscreen can be configured to show local weather, news, statistics about computer usage as well as media information (during playback).
The unfortunate drawback to the case (again comparing it to the Silverstone LC17 "Premium Deluxe Case" is that it isn't able to hold as many drives as the Silverstone. It is limited to one Optical drive and four 3.5" bays. Another minus is that it doesn't come with a mount for an SSD, so you'll have to buy that separately if you don't want to velcro it to the inside of the case. The 3.5" HDD bays are detachable from the Optical Drive and each have the ability to house an 80mm fan for even more air circulation. We opted to not install the additional fans to keep it quiet. Also there are already two 80mm fans mounted in the rear of the case that should be able to circulate the air enough on their own.
The case is able to house a full size board if you are wanting in install multiple PCI-E cards, as the AsRock H77m fit perfectly, with extra space for air movement.
The front of the case has a door that opens to reveal a single USB 2.0 port, along side a 1394 port, Mic In and a Headphone Jack. The other side of the case houses a Pro Duo, CF/MicroDriver, MMC/SD, and SM card readers. Above the door there is a volume knob and buttons that have basic navigation functions.
The touchscreen itself is backlit and can be programmed to show different bits of information, such as local time and weather, news feeds and computer information. The functions of the touchscreen can be changed by using the simple navigational menu, that functions similarly to Sony's "XMedia Bar." The one drawback to the touchscreen is the inability to turn off just the secondary screen itself. Yes it does dim during movie playback.
The unit comes with a programmable remote that can handle the functions of the HTPC, and according the the manufacturer's website, can be programmed to other units as well, which could help limit the amount of remotes needed for a Home Theater set up. The remote does, however, emulate most keyboard and mouse functions, eliminating the need for a wireless keyboard (but I recommend having one if you are going to be using the HTPC for more than Media Playback).
post #13 of 14
Any pictures of it dimmed? If I ever build a gaming HTPC, something like that is what I'd want to use.
post #14 of 14
Mine was the Moneual 932. In my experience, other drawbacks are that stereoscopic 3D drivers don't work with a dual monitor output (obviously, that's not going to be a common problem), and more importantly, turning off the TV and receiver connected to it moved the main display to the touchscreen, and then frequently when turning the TV back on, Windows for some reason thought it was a good idea to put the main display at 800x600. Unfortunately, in that case, there's no way I ever found to disable Windows' automatic screen detection, and so rather than constantly dealing with the issues I had, I disconnected the built-in monitor input. On top of that, I had issues with the iMon IR receiver not acting how I wanted it to... so yeah, for me personally, I wouldn't buy it again.
I know it sounds like an awesome idea, but I stopped even looking at the screen after a month anyway. But hey, maybe an expert will have better luck than I did (plus, I set this PC up around 5 or 6 years ago, so maybe the drivers and stuff have changed).
