AVS › AVS Forum › Audio › 2 Channel Audio › Looking for quality speakers for 2 channel iMAC set up
post #1 of 14
I am looking to upgrade my 2 channel system and I am torn on what speakers to get. The Ascend Acoustics CBM-170se are on sale right now, and they seem to be excellent speakers. There are so many options and I am having a hard time pulling the trigger. Can anyone recommend any other speakers in that price range that will be as good or better than the Ascends? I also have limited space, so these have to be around the same size. I will probably get stands for whatever speakers I end up getting
My budget $300-$450
I have a dragonfly DAC connected to my iMAC, and running it to a Emotiva USP-1. This is only for computer music (flac files, etc).
Any advice is appreciated
post #2 of 14
the ascends are very nice sounding speaker.another suggestion on the upper range of your budget are the kef q300 $470 at accessories4less. imo they are a step up in sound quality but for their price difference only you could judge if they are worth the extra cash. just my 2 cents
post #3 of 14
Unfortunately I do not have a way to listen to the ascend in person unless I buy them. I will check out the reviews on the KEF, I may be able to find a place locally to hear them. It really is a tough decision and I realize Im asking a question that is asked everyday all the time here.
I do appreciate the suggestion. I wouldn't considered the KEF's but looking at the Q300, they do look pretty nice.
Any other speakers I should consider?
post #4 of 14
What are you upgrading from and what attributes are missing from these?
post #5 of 14
I had a pair of JBL L820's that I used for my 2 channel set up. They were my surround speakers when I had all JBLs, then I upgraded from those speakers and used the L820s. They were pretty good speakers but I know there are better ones for sure. I don't exactly have something that I'm 'missing', but I do want to get the best for the limited budget I have.
I listen to mostly rock, hip hop, hard rock, some jazz etc. I mostly want to hear what others would recommend because I know there are so many options and I want to consider brands I otherwise would miss and all that.
post #6 of 14
I just picked up a set of PSB's new offering. So far, I'm pretty impressed with them. They are very clear, nice soundstage, and light bass (I use them in my office at work). I got them from Crutchfield since I couldn't find anywhere local to demo them and they would take them back if I didn't like them. I've decided to keep them.
post #7 of 14
Here's a few to consider:
Wharfedale Diamond 10.2
http://www.musicdirect.com/p-15479-wharfedale-diamond-102-bookshelf-speaker-pr.aspx
Arx A1b or Arx A3
http://www.theaudioinsider.com/index.php?loudspeakers=arx&cPath=21_32&osCsid=db20e1ddbbc1e37640b629b95a7d6fe6
Cambridge Audio - S30
http://www.audioadvisor.com/prodinfo.asp?number=CAS30
Monitor Audio BX2
http://www.audioadvisor.com/prodinfo.asp?number=MRBBX2
FOCAL - CHORUS 705V
http://www.musicdirect.com/p-41245-focal-chorus-705v-bookshelf-speakers-pr.aspx
Behringer TRUTH B2031
http://www.amazon.com/Behringer-B2031P-Ultra-Linear-Reference-Monitor/dp/B000LQ2ABK/ref=sr_1_1?ie=UTF8&qid=1334189010&sr=8-1
I have a pair of Wharfedale 70th Anniv. speakers for my office at home that I listen to for hours at a time. Silk dome tweeters give a very smooth upper register while the 5 1/4 inch mid woofers play down in the upper 40s - mid range is superb in my setting.
Good luck in your decision.
Edited by citizen arcane - 2/25/13 at 6:52pm
post #8 of 14
Which PSB's did you get? The new mini monitors?
post #9 of 14
These KEF speakers really have me intrigued and at those prices I am tempted to try them out. They may be a bit too big, but if the sound is better than the ascends, I can make it work somehow.
I don't know too much about KEF, but I know a lot of people enjoy them. Definitely need to read up on these.
post #10 of 14
Arx A1b or Arx A3
Monitor Audio BX2
FOCAL - CHORUS 705V
Thanks for the suggestions!
I read up on a comparison thread with the Ascends CBM-170se vs the ARX. The ARX looks like a very nice speaker and I would like to try a ribbon speaker, but I walked away from the thread convinced that the Ascends would be a bit better for my set up.
I am very curious about the Focals. I see these a lot on the music direct sites, but I never heard them. Anyone have these or the 706V and care to chime in on the sound quality?
post #11 of 14
Got the PSB Alpha PS1. They are going for 300 for the pair.
post #12 of 14
Well I went ahead and bought the Ascend Acoustics CBM-170se. I figured based on their rep, that I can't really go wrong. Plus I will be able to evaluate during the trial period. I think I made a good choice, and I'm looking forward to hearing these babies.
Thanks to everyone for their input!
BTW I called Ascend to order these and they did let me know that the sale has ended. The CBM's are no longer for sale.
post #13 of 14
congrats on your new ascends you won't be disappointed they are some very nice sounding speaks
post #14 of 14
Thanks man, I'm stoked to get these speakers. I should have them on Monday. I scored an audio rack and some stands from Craigslist yesterday, so once I put it all together I will upload some pics. Appreciate the feedback!
