Originally Posted by magnusvr
Hi R3zon8,
wow, I have been looking for a writeup like this for a long time, thank you! Very keen o try it! I have a 411j but feel that it is too slow.
But:
1. Do you still get the SHR "hybrid raid", or are the drives suddenly handled only by the N40L microserver?
Answer myself: Never mind, I see above that you mention SHR, good.
2. I guess updating the Synology the ordinary way is out of the question? How would we be able to update other than await a newer package from you? DSM 4.2 is out today for instance. Want!
3. The N40L, is Intel-compatible right? Thinking of the Plex plugin which only supports transcoding in intel based Synologys. The N40L has an AMD, I guess that will count as Intel based?
4. I get 5 drive support with the N40L and hacked Bios? Not 4+1 or anything like that, IE I can have 5 drives in one big raidset?
5. Do we know of any good way of extending the number of drives of the N40L, like an external SATA tower and a PCI-card? Just toying with the idea.
6. So the 1 Sata drive required, will that always be allocated for the OS and prohibit for storage use, or can you make a 5 drive hybrid raid from start?
Answer: Never mind, also now read that you mention 1 minumum, I'll read that as a 1-5 drive SHR.
Thanks for posting this!
KR
Magnus, Sweden
Hi R3zon8,
But:
KR
Magnus, Sweden
Hi Magnus,
Youre welcome.
1. Yes, you can create a SHR and/or any other type of raid that DSM supports.
2. 4.2 is still in beta IIRC, when 4.2 final/GM build is released I will update my OP.
3. Yes, N40L is x_86 based. It will work.
4. Yes, 5 drive volume.
5. Add a SATA controller based on the chipset I listed as compatible and you should be able to add more ports/drives to the N40L. Where you fit them is another story.
6. 1 drive is required when you run through the installation the first time. DSM required this to install itself. If your unit is fully populated from Day1, yes create a 5Drive SHR during installation if you wish.
