Originally Posted by
Nbaylot46
Ah yes, I knew the fireplace would be an obstacle. Now in your most persuasive voice sway my wife lol.
OK, you asked for it--I'll try my best. (Summoning my deepest, most authoritative baritone)
WOMAN! Your husband asked us for our considered opinion on this matter. The TV belongs on the left wall, and that's where it is going to go, so you might as well learn to deal with it!
Nbaylot46, I hope that your sofa is really comfortable to sleep on--just a friendly heads-up.
Nbaylot46
I do not know the dimensions of the wall. The Tv on that wall is a 46 if that helps.
Yes, the wall is therefore about 6 feet wide (conservatively), and the fireplace mantle is about 5 feet wide. That should be large enough to accommodate most TVs and a fair variety of speakers, but may present a problem for in-wall speakers unless your TV is really small.
Nbaylot46
At this point I would consider anything except towers (you know who). It has to be mounted or in wall/ceiling. I looked into energy cb5/10 around with matching center and a bic pl200 with a denon avr 1613 but am concerned about size of the speakers and how large is too large for mounting on wall.
That's what I wanted to know, because the for sound quality your best option would be wall-mounted bookshelf speakers of minimal size (although tiny is not quite going to cut it in a room of this size with the distances involved). The Energy CB-5 is obviously better for aesthetics than the CB-10, but on the other hand the CB-10 is really the minimum size for good sound, if that.
Nbaylot46
Maybe two bookshelves in front pointed towards us and ceiling mounts with directional drivers for side.
I'm thinking now that maybe a better compromise for the surrounds would be on or in the walls, the right surround on the top wall (in your diagrams) as far from the TV as necessary in order to bring it generally in line with the right sides of the viewers, and the left surround on the left side of the bottom wall. In-ceiling surrounds would ideally be close to those positions anyway so that their sound wouldn't seem to be coming from way above the viewers.
Nbaylot46
I am perplexed about the front right placement.
Well, you could mount the front left & right speakers on the same wall as the TV, one on each side of it, or on the top and left walls not far from the TV, the right one being just to the left of the window. In the latter case, you would want to use mounts that can swivel, such as the OmniMount 20.0.
Nbaylot46
I like these systems.
1) Energy cb5/10 x4
Matching center with bic pl200
2) def tech pro cinema 600
3) klipsch hd 1000
4) Polk owm5?
5) I believe I read in a post somewhere about htd level twos surround and bookshelves. How are these?
I actually looked into the HTD level TWOs for you earlier, and they are well liked, but like the Energy speakers they may be a bit on the large side for your situation, aesthetically speaking (you tell us)--that's why I hadn't mentioned them. The others are smaller but may not have enough "grunt" for this size room. Obviously, like most things in life, you may have to compromise. One of the best points of compromise that I know of between size and output capability in typical home theaters is the Ascend Acoustics HTM-200 SE:
http://www.ascendacoustics.com/pages/products/speakers/htm200/htm200.html
Its cost is a bit high for your specified budget ($468 for three or $722 for five), but you could get away with smaller, less expensive speakers for surrounds, such as some of the ones you mentioned above or the Polk OWM3, which is small and pretty thin. The HTM-200 SE is also a better speaker than the others--in a different class, really, in my opinion. And because of its highly offset tweeter and closely placed midwoofers, it has quite good dispersion when oriented horizontally, which means that you could potentially place three of them across your mantel, sort of like a soundbar (but far superior). Its relatively shallow depth for its size (only 6 3/8") and output capability may help with placement, as well.
Nbaylot46
Denon avr 1613 is most likely the receiver
I have a lot of openness and want to address that.
This would be a solid choice, and if you wouldn't mind buying a refurbished unit, you could get one for $230 (plus shipping):
http://www.accessories4less.com/make-a-store/item/DENAVR1613/DENON-AVR-1613-5.1ch-Networking-Receiver-w/AirPlay-3D-ready/1.html?c=t5
Or the 1612 could be had for $200 (plus shipping):
http://www.accessories4less.com/make-a-store/item/DENAVR1612/DENON-AVR-1612-5.1-Channel-A/V-Home-Theater-Receiver/1.html?c=t5Quote:
Nbaylot46
I don't know much about in wall / ceiling
Neither do I, actually, but I know that they entail additional placement issues regarding the internal structure of your walls, whereas small bookshelf speakers could be placed or mounted almost anywhere you could fit them.
Nbaylot46
Another question... Lets say I can't do in wall in the fireplace wall. What about four in ceiling directional with a center on the mantle? How bad is the sound going to be for the fronts?
As you suspect, it would be bad--you might be able to get away with it with the surrounds, but it's never good to have your front soundstage come from the ceiling. Having a regular center on the mantle would help a lot for some things, such as dialogue, but then it wouldn't mesh well with the other front speakers. If you were going to place a center speaker on the mantle anyway, then you might as well place the others on it, too--despite the narrow separation, it would be better than in-ceiling placement, in my opinion.
Edited by Robert Cook - 2/28/13 at 11:28am
