Need help with crossover settings, I'm not sure what I should have these at and I've been playing around and probably have them all fubard..
My Center and L/R and Infinity Primus 163 6.5" woofer. I have those set at 100hz
My surrounds are Primus 153's 5.25" woofer and I have those set to 80hz.
Does the hz setting mean they wont play anything lower than the setting or higher? lol
I've changed them from 60-80-100 and haven't really noticed a whole lot of difference, but I'm not sure what to look for or a good way to test them. I suppose I should turn the subwoofer off though when trying to hear them and I haven't done that yet.
I'd go with 80Hz for all channels, try 100Hz with the 153s (and also 100Hz for all channels) for good measure, and go with whichever setting(s) provides the best overall blend of sound between speakers & sub.
