I recently purchased a home that has prewired CAT5 for telephone and internet, as well as cable.
The wiring is run to an ON Q enclosure.
The telephone jacks, from what I can tell, are (quite messily) wired up.
In each of the bedrooms, bonus and office, there are a double keystone jack containing cable and ethernet. In each of these rooms is a separate jack for the telephone.
My question is:
What do I need to complete this setup? The white cabling is CAT5 attached to the jacks in the rooms.
I am thinking I need:
A crimper, RJ45 jacks and an ethernet tester to finish the CAT5 cables in the panel. Also an 8 port switch :
http://www.newegg.com/Product/Product.aspx?Item=33-122-111
and and cable distribution panel like this:
http://www.amazon.com/On-Q-Legrand-VM1002-Enhanced-Splitter/dp/B000S9IRDU/ref=wl_it_dp_o_pC_S_nC?ie=UTF8&colid=180BCLXMF17RR&coliid=I2KNCL8MJMZ3UT
And a power strip like this:
http://www.amazon.com/On-Q-Legrand-36426601-Power-Strip/dp/B00035I4SC/ref=wl_it_dp_o_pC_S_nC?ie=UTF8&colid=180BCLXMF17RR&coliid=I1JBRZWFF9NQF3
Move my cable modem (comcast) to the enclosure, hook to switch and then run wireless router from ethernet port (now live) in office.
Thoughts?
My question is:
Thoughts?
