AVS › AVS Forum › Audio › DIY Speakers and Subs › lt.1300 and lms 5400 ultra
post #1 of 8
So I've been waiting for the you UXL-18 to come back into stock and I was going to build a small sealed box and power it with the lt.1300. But I have a chance to pick up a used lms 5400 Ultra locally for a good price. My question is, would the lt.1300 be powerful enough for the LMS 5400 ultra?
post #2 of 8
winisd
post #3 of 8
Real world power on that amp was around 1,000 watts. Will it work, yes. Will it work well, not really.
post #4 of 8
You will not be happy with the output of the 1300.
I had one, and I sold it. FP14k clone is a much better value for the money.
post #5 of 8
You won't know if 1000w is enough unless you try it.
However, unless you can buy one for under $150 it would not be worth it.
You can get some real world power from an affordable pro amp like the EP4000 for less than $300.
post #6 of 8
I already have the lt.1300 and won't be able to purchase any more amps for at least a few months
post #7 of 8
You would be better off with a driver that would make full use of 1k watts. If that amp has a HPF a ultimax 15 would be s good choice, and its only $200.
post #8 of 8
If you already have, try it!
I used a 1000w amp with my first 5400 and it did pretty well.
You could always go with a larger cab to increase the efficiency, say 5 cubes.
