AVS › AVS Forum › Audio › Speakers › Need help with my home theater speak setup
post #1 of 6
Hi,
I am a novice home theater user and had a couple of questions related to the speakers installation and set up.
I am using a Denon 3808CI receiver and plan to connect to Infinity speakers. I have two possible configurations:
6 Infinity (floor standing) P363 and Infinity PC351 for center channel.
or
2 Infinity (floor standing) P363 for front speakers, Infinity PC351 for center channel and Infinity P163BK for surround and rear speakers.
I intend to get a Hsu Subwoofer.
Can you please advice on any pros and cons of the above possible combinations?
Also,
Is it true that I should have the speaker cables having identical length (say for two front speakers) even though the speakers are not at the same distance from the receiver?
What kind of cable should I be using for these speakers?
I had a basic question about banana plugs (I've never used them before). What kind of banana plugs should I be using for the speakers and the receiver?
I would highly appreciate any response from the experts.
Thanks a lot.
post #2 of 6
I generally use the same-length cable for the corresponding speaker pair, like Left/Right, Surround Left/Right, etc. I don't think it matters all that much since Audyssey will set up your delays accordingly.
As far as cables, there is a thread on how to make your own cables. You can also buy ready-made cables from Monoprice, Parts Express, or Blue Jeans Cable.
You can terminate with Monoprice banana plugs, but I think Nakamichi or GLS Audio bananas are better quality.
I don't have Infinity speakers, so I cannot comment on them. As a general rule, I usually recommend using a similar driver configuration for the Left/Center/Right speakers. Looks like the PC351 is the best option you have with the P363 even though it is .75, 3.0, 5.25 vs. .75, 4.0, 6.5.
I have a 5308ci. Beauty of the 3808ci is that you can add an external amp if you need more power.
post #3 of 6
The speed of an electron wave through wire is roughly 680 million feet per second. eek.gif I wouldn't worry about getting the wires the same length,
Copper speaker wire, from the least expensive source. Use this to determine the gauge you need:
http://www.bcae1.com/images/swfs/speakerwireselectorassistant.swf
They're optional, there's no need to use them at all. If you want them get them from the same place as the cable, don't pay more than four dollars apiece.
post #4 of 6
Thanks for your response.
Sorry if its a dumb question, but I didn't understand the numbers (.75, 3.0, 5.25 vs. .75, 4.0, 6.5) in your response.
So, in your opinion, when using P363s, would I need an external amp? If so, which one would you recommend?
Thanks again.
post #5 of 6
Those numbers are driver sizes, but I think the important thing is that the tweeters match.
And my guess is that the p363 would be driven by most decent avr!
post #6 of 6
I plan to use Denon 3808CI.
  Back to Forum: Speakers
