I currently own a JVC RS20U and I am looking to upgrade. It will be primarily for 2D viewing but would like to have the option for occational 3D. The screen is 120" Pifer Sheerweave in a light controlled room but with white ceilings and light colored walls.
My two options are :
1. a new RS46 with full warranty and a 1yr warranty on the lamp
2. a used RS60 3D with 300 hours on the current lamp and a new sealed gen 3 lamp.
They priced about the same. I am not sure if I should go with the older RS60 for the higher contrast or the newer RS46 with the same contrast as my older RS20 but brighter.
All suggestions / advice is welcome!
