I have a Cambridge 650R receiver and the Cambridge 751BD blu-ray player. . . The receiver has speaker distance & level calcs on it but so does the 751BD blu-ray player.
If I set the received first then the imaging, levels etc sound good for TV, PS3 etc . But the blu-ray must have slightly different balancing as material that comes from that if I leave all levels at default in the blu-ray player are out. I.e surrounds volumes.
What I have done is then made additional changes in the blu-ray player to levels for speakers to make them correct for movies, music etc when I play things from that source through the AVR and not just from the AVR such as TV and PS3.
But what about distance calculations?
Do I do distance cals at the receiver only or enter in the same distances on the blu-ray player or would that be doubling the distance?
