AVS › AVS Forum › Gaming & Content Streaming › Networking, Media Servers & Content Streaming › *Official* Dune HD TV303D/ Base 3D Streamer Thread
*Official* Dune HD TV303D/ Base 3D Streamer Thread - Page 11
post #301 of 1165
Originally Posted by Skylinestar View Post
I can't find any HDMI CEC settings in the TV303D. On my Sony, HDMI CEC is switched off.
Perhaps you guys can test this for me: Hookup the TV303D to your TV (through HDMI, TV without dts support). On the Dune, set the audio to HDMI Original (Bitstream) 7.1. Then, play a few movies with DTS5.1 track.
If you're "bitstreaming" to a device that doesnt support that audio codec, it wont work. Which you've stated your AVR can't. So you need to set the Dune to "decode" before sending to the AVR.
Unless I'm completely misunderstanding what you're trying to do.
post #302 of 1165
Originally Posted by bytebuster View Post
Folks, I understand that the new Zappiti mini player hardware is essentially the 303
Will the mini be available in the US and also, is there any benefit in getting this over the 303?
Also, do the 303s do a good job with 23.976
I know the D1 did a great job
mini will be available in the US. I honestly see no reason to get the Zapp player over the standard Dune just simply because of the extra premium, especially now that you can boot directly into Zappiti. You do get the Zappiti music jukebox if you would like that, and whatever other "enhancements" the Zapp developers might have planned. I think as well updating fw is a different step then how you do through the Dunes (maybe someone with a Zapp player can confirm t his)
post #303 of 1165
Surprisingly that with bitstreaming, my Sony (which doesn't support DTS) is picking up LPCM 2ch. I've also attached the screenshot in previous post.
Originally Posted by GusGus748s View Post
It will be available, who knows when. Contact Mike at Duneplayer.com may be he has an idea. There is no benefit, they are the same media player. With the Zappiti player you can use the Zappiti Music jukebox option.
According to the specs here, "HD audio support: pass-through (up to 7.1 channels)." is officially stated. This statement is definitely missing from the main Dune's site.
post #304 of 1165
In theory even those specs are incorrect as it mentions downmix to PCM (you need to apply the patch to get PCM downmix of DTS).
As well those specs still show MVC as a supported video format which we all know isn't true.
post #305 of 1165
HDMI's EDID feature allows the receiver (or TV) to tell the Dune what formats it supports. The Dune then detects that bitstream of DTS is not supported, so it decodes it to LPCM and sends that instead.
Is this causing a problem for you?
post #306 of 1165
Yes the mini should be available in the US.
The difference between the mini and the 303 is only software. The mini came with Zappiti full licence that included the music jukebox and also all the "coming soon" Zappiti dynamic functions..
As for the 23.976, yes the 303 do a really good job.
post #307 of 1165
EDID seems like the best explanation. Thank you very much for the hint.
post #308 of 1165
Can anyone tell me, what audio DAC is in Dune HD Base 3D ? Chipset, name or technical parameters...
post #309 of 1165
I manage to replicate the "random noise" issue that some users have complaint by playing different file types (with different audio encoding). When the video is played but without audio, stopping the video, which then returns to the menu, will generate the loud noise. When watching a movie (such as MKV file), jumping to a time (by the up/down button on remote) can create the weird noise too. Pressing pause then resume/play will the solve the noise issue. Perhaps the audio fails to catchup with the video frame.
I hope the next firmware, B7, can solve this issue.
post #310 of 1165
Is the Base 3D infected with cinavia?
post #311 of 1165
No, because it doesn't have a Blu-ray licence that enables it to play the menus. Anything that is manufactured after Feb 2012 that does have a Blu-ray licence will have Cinavia enabled.
post #312 of 1165
Good to know, thanks.
post #313 of 1165
303D/base are the only choices now. Looks like the H-1 is gone.
post #314 of 1165
If I have receiver that support DTS HT, HD Dolby, is It ok to turn off EDID? I am trying if there is reason to turn it off or on. I turned off it thinking that it will turn on/off devices automatically and some times confusing. I always use Logitech remote to start activity.
post #315 of 1165
I think you are confusing EDID with CEC. It's always safe to turn off CEC.
post #316 of 1165
Sorry. Yes. I always turn off CEC and I turned off EDID also. If my receiver has all audio decoders, not sure if the protocol overhead might delay or confuse devices. I do bitstream from Dune.
post #317 of 1165
How to set the TV303D to always prefer external SRT subtitle (if available) instead of internal embedded subtitle?
post #318 of 1165
SETUP > PLAYBACK > SUBTITLES > DEFAULT SUBTITLE PREFERENCE FOR FILES
post #319 of 1165
Any update as to when we might see an official firmware update to these new line of players? Not anther beta version. Waiting to install a few for clients.
post #320 of 1165
I have some questions about the dune base 3d i might be interested in replacing my popcorn hour a-300 with one
ive always used popcorn hours so here is some questions
right now my setup is as follows
i have one flash drive plugged into the front of my popcorn hour and a usb hub plugged into the back with 7 2tb drives and 1 3tb would this work on the dune base 3d?
i will most likely only be using the basic file browser
Can i copy from drive to drive through ui?
I have all drives attached to my popcorn hour showing on my windows pc can I accomplish this with the dune?
can i mark things as watched in basic file browser?
does internal drive need to be formatted? is there apps that need to be installed?
What are current known bugs?
Coming from popcorn hour is there auto framerate and any issues with it?
I think I read there is a headphone jack on this can someone confirm that?
Is there a usb slave?
This is included in the standard unit? HDD Rack Option with Hot Swap
Function does this mean I can take the drive out plug and play basically?
ive read about some audio issues can anyone go into detail on those?
i think thats all my questions for now if i can get answers to these it would be greatly appreciated
post #321 of 1165
post #322 of 1165
Recently picked up a 303D. Blu-rays I have recently ripped to mkv with Makemkv will not play. They play fine on my Mede8er and PC. All have all been ripped with the HD audio track. I am bit streaming to a Denon 4811. I am wondering where to start trouble shooting. 303D is setup to bitstream audio.
post #323 of 1165
Did you update to the latest firmware? I don't have any issues with MKV files done with MakeMKV.
post #324 of 1165
Updated to B6, then backed down to B5, no luck with either.
post #325 of 1165
I assume these are 2D Blu ray rips and not 3D Blu ray rips, correct?
post #326 of 1165
2D. Puzzling. I haven't isolated True HD vs. DTS-HD yet. I will do some sampling tonight. So far the few I have tried have all been DTS.
post #327 of 1165
That is odd, I have no issues with mkvs (DTSMA or TrueHD) if bitstreaming. Could it possibly be one of the video settings that is off. Do you have auto framerate on?
post #328 of 1165
Not experiencing these problems and I rip everything with Makemkv, but go into an Onkyo amp via hdmi not optical and via bitstream
post #329 of 1165
Tried with auto framerate on and off. Beginning to wonder if it has anything to do with my Lumagen settings.
post #330 of 1165
Lumagen ?
Check here from post #129 and after : http://www.avforums.com/forums/streamers-network-media-players/1554496-dune-hd-smart-h1-owners-thread-5.html
It's for a smart but should work in the same way for a 303d (except that you can't turn Hdmi CEC off with the 303d...)
