AVS › AVS Forum › Gaming & Content Streaming › Networking, Media Servers & Content Streaming › *Official* Dune HD TV303D/ Base 3D Streamer Thread
*Official* Dune HD TV303D/ Base 3D Streamer Thread - Page 17
post #481 of 1165
Originally Posted by jconjason View Post
What i mean is, the dune 3d players cannot play trailers, menus, etc. ISO must be played in "lite" mode, which is just the main movie.
How does the Dune know what it's playing? Isn't the video the same format (m2ts) regardless of whether it's a trailer/preview or not?
post #482 of 1165
From my understanding, they don't have the BD license, so no menu support. Other wise you'd have cinavia, which nobody wants.
post #483 of 1165
OK. Let me ask some other basic questions.
1) If I copy/rip an iso, you are saying that only the main movie will play on the dune, right?
2) If it is a 3D disk, then the movie will play in 3D, right?
3) Do I need to copy/rip and store 2 .iso files of the same movie if I want to watch it in 3D or 2D?
post #484 of 1165
Also, don't forget, the Dune 3d will not play subtitles in an .ISO format.
MKV files doesn't support 3D.
I know Dune is looking into the subtitle .ISO issue, but not sure about the MKV 3d issue. Either way you will lose on something as it stands now.
post #485 of 1165
I thought it was only the forced subs that were a problem.
post #486 of 1165
MKV does support 3D, MakeMKV can rip to MVC MKV, the mede8er players handle 3D MKV files fine. Dune and PCH don't support MVC MKV files.
post #487 of 1165
And just to go off this a bit I doubt we will see support for it in anything else, PC based players are not even supporting it with the only one being stereoscopic player which is hit or miss. Until other players jump on board and other software rippers, its looking like a dead format at the risk of encoding everything over to mvc/mkv then when the only player that supports is no longer around you have to re rip your whole library again. I would love to see mkv/mvc be widely used as I hate ISO files but its not looking like its going to happen. Not to mention last I herd they never did agree on a standard way for mkv. Makemkv just happens to do it one way and the people really do not like it you can read some of the discussion here
http://lists.matroska.org/pipermail/matroska-devel/2012-November/004314.html
Edited by halfelite - 7/3/13 at 4:38pm
post #488 of 1165
I'm sorry... I meant in relation to the dune 3d. Thanks for making that clearer.
post #489 of 1165
Looks like this is more of an issue with HD audio tracks (dts-HD especially)
Damian and all, any idea if Dune is aware of this issue.
I don't recollect the dune smart boxes suffering from this
post #490 of 1165
Hoops2 ; dont have a dune [tvix3ds2 ] but in relation to choosing the dvdfab main movie profile for 3d frame packed you can buy the bd copy module to get the latest coding . I use 3d bd ripper myself to make smaller file sizes m2ts 3d's but you can use the free hd decrypter to make a main movie iso ;its pretty intuitive and it helps the file size some smile.gif
For question 3 one iso is fine any player will just choose the left or right frame or you can adjust your panel /projector and even some active 3d glasses cool.gif Some bd boxsets have separate 3d/2d discs and some have both on the one ; these multiple disc/download file types can even be conditional on which country you buy from so it pays to check say amazon uk as well as the original sometimes ..
don't need menus, alternate languages, alternate audio, previews,
That's doable with fab 3d ripper ; I just pick 1 lossless track and 1 eng subtitle file and hit remux [ another benefit of the m2ts profile ] . An iso or using bd copy to make a folder you get sometimes 10 or more different language subtitles as well as lossy soundtracks tongue.gif I only make iso's when a problem disc turns up with the subs out of sync or something otherwise shrinking the files i cant pick the difference wink.gif
Edited by cwt - 7/4/13 at 12:08pm
post #491 of 1165
Originally Posted by Skylinestar View Post
Did you try to pause and resume playback?
We're all waiting for Dune to fix the annoying audio bug (loud white noise, audio hiccup, etc)
What the **** that isn't fixed yet? Why not??? I had a small problem like that with beta 3. Now I have beta 6 running and couldn't see/hear that problem anymore but it's still there? How is that possible.....
Secondly what about the subtitles. When you have a BDMV folder (2D) and play the movie you can't use the existing embedded subtitles anymore? Wtf?
post #492 of 1165
Which issue specifically, I haven't run into this with the beta 6 fw (the DTSMA issues I had was with the older fw)
What do you mean you cannot use, you can't select the subtitle track?
post #493 of 1165
I am currently using 130114_1511_b3
How do I get beta6. The firmware upgrade menu on the dune shows beta 4 available
With my current firmware I see audio drops with dts-hd after pausing and resuming playback
post #494 of 1165
You need to continue the updating process, until you reach the most current firmware. You cannot get beta 6, until you've updated to the previous others. I must have updated my 303D four times in a row out of the box, until I got to the most current one..
post #495 of 1165
b3 is a bad one which is why you are still seeing the DTS bug. Update as per L33TX43RT
post #496 of 1165
I just selected b4 and the screen just went blank
post #497 of 1165
Power cycle the unit, from the switch in the back. Try again. Make sure your Internet network is properly connected to the unit.
post #498 of 1165
I wonder if the box is switching o/p video resolution
post #499 of 1165
This isn't good.
THIS IS A LAST RESORT... If you're stuck, you may want to perform a factory reset with this file on your DUNE player, and wipe the flash memory. Simply put this file in a shared folder or usb drive to your DUNE player, and execute it from your DUNE browser.
Afterwards, try the update process again.
post #500 of 1165
Ok upgraded off flash instead and that worked
Weird. Thanks guys
post #501 of 1165
Is it possible to downgrade a firmware? (example from b6 to b5).
Is there any extra procedure?
post #502 of 1165
I haven't dared to try it, but I do not see why not. However, I have noticed some performance issues with the newest beta. *notes downgrading to self*
post #503 of 1165
Yes, you can downgrade
post #504 of 1165
Had a bit of a breakthrough today, streaming high bitrate MKVs via PLEX Media Server, wireless to the DUNE player w/ Plex plugin. I just ran through an entire movie of Prometheus peaking at 35.7 Mbps, without a single hiccup on DTS HD-MA. I confirmed this with a skimming through my other 1:1 MKV rips, to make sure it's not a fluke. On the plus-side, PLEX Media Server supports Movies, TV, and music. The software it still in its early stages, so it's a tad buggy which can be worked around. Furthermore, I'm happy with the results so far.
The Dune client is called Emplexer. It's still in beta, yet the author is regularly on his own forum to oversee the feedback coming in, and resolving current issues with the software.
Edited by L33TX43RT - 7/6/13 at 3:48pm
post #505 of 1165
Can you tell me if you used NFS? If so, please let me know your settings on the Dune (for emplexer). I have not been able to get this to work (using plex). I do see my movie posters, but clicking them won't start playback.
post #506 of 1165
I am going to continue to use my 400 disc changers until I'm completely backed up, at which time I'll swap out the changers in the rack for Dune media players. I don't have the players yet. My question is, can I install YaDis in advance on the server so I can scrape as I go and have it all done in advance?
post #507 of 1165
Is the downgrading process 100% same as upgrading? Select the dff file and hit enter?
post #508 of 1165
I haven't fiddled with it much, and still have it on "http", which the lag is terrible. As far as your problem goes, make sure you Plex IP settings are the same as the computer Plex is installed on, with the default port number "32400".
Yep. I tried downgrading yesterday, and it's the same. The only files available are b5 and b6.
post #509 of 1165
Thanks for the info.
Just for sharing...official links to the firmware:
http://dune-hd.com/firmware/online_upgrade/tv303d.txt <---not really the latest
http://files.dune-hd.com/partners/sdk/sdk.txt <---check here for the latest
post #510 of 1165
Oh, nice find. I was referring to the firmware released available on-screen, through the DUNE player. biggrin.gif
