AVS › AVS Forum › Gaming & Content Streaming › Networking, Media Servers & Content Streaming › *Official* Dune HD TV303D/ Base 3D Streamer Thread
*Official* Dune HD TV303D/ Base 3D Streamer Thread - Page 25
post #721 of 1165
Just picked up HD TV303D - in few day of messing around - exactly what I was looking for in a WD TV Live upgrade ( had for couple yrs)
I mostly just use for streaming MKVs off Iomega server and win 7 PC's.
biggest upgrades for me over the WDTV -
DTS-MA and TrueHD bitstreaming - flawless
getting proper Video display and frame rates - WDTV was always PIA and reverting to default settings.
have not had any freeze's up - WDTV was locking up a lot and requiring hard resets
and added bonus for my CIH set-up - Subtitle shift - awesome feature
recommended
post #722 of 1165
recommended
Which firmware version are you at?
Try this:
Play MP4 file, play MKV with dts, play MKV with DD, play AVI with DivX, then VxiD. Report your findings.
post #723 of 1165
Try this:
Version "130515_2104_b6"
MP4 file, MKV with dts, play MKV with DD, are all good . don't think I have anything with AVI or DivX
post #724 of 1165
Originally Posted by kevinsert View Post
how im gonna take screenshot from movie? its black screen everytime i try.only i can get screenshot from menu
no reply?
post #725 of 1165
My Smart D1 just showed up today. Gonna treat that thing like gold, might even buy another.
post #726 of 1165
Congrats. Do you mind if I ask how much did you pay for it?
post #727 of 1165
Not at all... I paid what Mike has them on his site for, I think 349, or 369?? I can't remember.
post #728 of 1165
It's been 3 months since the last firmware release :cry:
Mine is a little buggy.Cant wait for a new firmware.Has been a while.
post #729 of 1165
currently trying to decide between a popcorn hour a400 and a dune 303d/base 3d.
I really love the casing on the base 3d but the only way it would fit in my enterainment system is if i could sit my ps3 on it. Would that damage anything? base 3d has a fan, i will not be putting a hdd in the base 3d as of yet and the base 3d / ps3 would never be used at the same time.
also, opinions of base 3d/303d vs popcorn hour a400?
post #730 of 1165
Base 3D gets my vote of the three. It's what I own. ;-)
post #731 of 1165
What are the major bugs of the Base 3D after the b6 firmware?
I have several Base 3.0 and Smart H1's, but I need to add two more units to my system. I know there were lots of complaints with bugs when the Base 3D was released (audio dropouts, not TrueHD decoding, etc.).
All my media are 1080p MKV files with either DTS-HD or TrueHD tracks (the secondary 5.1 tracks are not present). Some have internal PGS forced subtitles. In the case of these two new installs, they will be connected directly to a TV with no HD audio decoding. In the past, I have just used the Dunes to downmix to two channel audio directly from the HD track and output as PCM to a stereo TV. Also, some of the content may be 50 Hz and the TV's are not capable of 50 Hz (previous Dunes converted 50Hz material to 60Hz).
I also use the Dune rsync utility as well as a couple of other Dune utilities to keep my jukeboxes updated. Are there any problems with these on the Base 3D?
Is the Base 3D still buggy in any of these areas? What problems will I notice when compared to the Smart H1's as far as MKV files?
post #732 of 1165
TrueHD from an mkv will not be downmixed, so you will get no sound (this is not a bug, this is how the 3D model was designed based on licensing). You can always just add in an AC3 track to those mkvs
post #733 of 1165
Thanks! Looks like I will be scouring the secondary market then, as that is a deal killer.
I could externally extract all HD tracks, convert TrueHD to a DD 5.1 track, and then remux that track back in. But I'm sure that would be hundreds of files, dozens of hours to accomplish, and would increase my storage requirements. I also don't know if the TrueHD track was default, would it automatically switch the the secondary track, or would it play silence till manually switched?
I think it would be more practical to buy used players until such a time that Dune gets on board with TrueHD licensing. I may have to pay the extra money to get a new D1, but I would rather have an H1, Base 3.0, Duo or the like (removable drive bay).
post #734 of 1165
Yeah, depending on how many TrueHD mkvs you have it would be a PITA.
The default track will automatically load, so if that is the TrueHD track you will need to manually switch to the AC3 track
With the current 3D models I don't see TrueHD licensing ever coming to.
One option if you don't want to spend as much on a new Smart, contact Mike @ Duneplayer. I believe he has a bunch of refurbs that you could get for cheaper. For example, I think he has a bunch of B1s where the ROM drive no longer works but everything else works perfect (i.e. so if you are not looking to use the BR Rom drive it would be no different then an H1)
post #735 of 1165
Been using an A-400 for a while thinking that 3D would be a draw. My wife is fairly resistant to 3D though. Been ripping main movies to MKV on my Synology. I'm thinking now that if I wanted to skip 3D, I'd rather be running an older player capable of real BD menus off a full disc rip to ISO and just pay for the extra storage to keep the extra features on the discs.
Would the best bet for that be an older Dune Smart series player?
Do those players have any issues with playing the most recent BD releases?
Will those Dunes handle forced subs properly in a full disc rip to ISO?
Will those Dunes handle seamless branching without any stutter in a full disc rip to ISO?
post #736 of 1165
Only problems they have is with fox titles. But if you are ripping to ISO rather then retail disc you will not have that issue
post #737 of 1165
I rip to iso on all files.Both my older dunes play them without issues
post #738 of 1165
1. yes, Smart/max/duo arethe most stable 2D players. the problem is to find one to buy...
2. B1/Max are unable to play any fox title released since mid-2012. No problem once ripped (with full menu)
3. not used to forced sbus, will let someone else answer, but i think every players from any brands are struggling in some way with forced subs.
4. old dune range will play seamless titles without stutter or audio drops. just perfect.
post #739 of 1165
I have a couple of questions as far as the Dune Base 3d. It seems like most people are using mkv container for their movies. I rip iso for my movies so
1) As far as blu ray movies are concerned do seamless branching blu ray 3d titles have drop out in iso form?
2) Seamless branch on standard blu ray movies in iso form (non 3d) shouldn't have a problem if i use something like clown bd and just rip main title?
3) Any titles with TrueHd will downmix in iso form but not in mkv?
All my blu ray iso i use clown bd and just pick the main movie. The few 3d titles i have i do have the full iso image ripped as well.
post #740 of 1165
1. on all 3D models seamless branching is a problem, whatever container you use except mkv. Problem : for 3D movies the dune 3D models are unable to play 3D mkv MVC, which gives you no solution to correct this problem for seamless titles (assuming you would be OK to change your 3D ISO into mkv).
2. outside the easy to rip mkv solution (because it would keep the BR structure and is fast to do), yes, ripping as one big m2ts is another solution, but with some seamless titles having 50+ segments (mainly disney) it can be complicated to do.
3. in fact I think that THD, whatever format is used, just doesn't output any audio when downmixed, you would have to remux to AC3 5.1 your THD track (not 100% about that, so someone else might confirm).
post #741 of 1165
TrueHD will not get downmixed regardless of container. HOWEVER, there is a difference when using an m2ts container versus mkv. With an m2ts container (such as a Blu ray folder structure) an AC3 track is embedded in the TrueHD track. In a case like this, the Dune would simply grab the AC3 track (so you would still get sound, albeit from the AC3 track). With an mkv you cannot have 2 audio tracks in one track, so you would end up just having one track with TrueHD. The Dune cannot downmix this so you would be left with no sound (or another option would be to add a second AC3 track, but you would need to manually switch over to that track during playback unless you set it as default)
post #742 of 1165
so in fact m2ts is the solution for both seamless and THD rips ?
post #743 of 1165
The older Dunes handle forced subs in properly-ripped ISOs just fine. (Getting a proper rip can be a challenge, but that's not Dune's fault.)
post #744 of 1165
I wonder if there was a way to remove the ROM drive and somehow install a hot swap bay (ie, homemade H1). On all my dunes, I have the hot swap bay with a SSD in it for storing my index. I rarely ever swap one out, but the bay makes it nice when I do. I already have lots of hot swap bays from a server tear down, so I wonder if that would work. If I could get a B1 cheap enough, it might be worth a shot...
I contacted Mike about an H1, but he said those ships have sailed and are long gone.
post #745 of 1165
yes, except you lose chapters if you just do a standalone ts/m2ts. Also, not sure if forced subs will work (they work with mkvs b/c of Scotts patch)
post #746 of 1165
I would discuss with Mike. I have a B1 but not gonna take it apart to give you an answer biggrin.gif
post #747 of 1165
Good luck finding any Smart Series for less than $300 used. I've been keeping an eye on eBay, and several Dune Smart Series D1 / H1 sold for almost $400 dollars USED! eek.gif A Dune Max last week sold for over $400. These prices do not include shipping either.
post #748 of 1165
help!!!
post #749 of 1165
That's all you'll get out of the screenshot.
post #750 of 1165
Hi everyone,
Just some news to clear the air on the state of the Dune HD Smart Series and Dune HD Max players.
There is currently no longer any inventory of the Smart series or Max players since the last production run, and the Smart Series units have been essentially replaced by the Base 3D and 303D players. As always, the firmware will continue to evolve over time with these units. The feature requests and bugs noted are constantly being explored by the firmware team. For those asking, we have no timeline information on a next generation 3D player with full Java menu control at this time.
But…
With all that being said, the demand in the USA is so high for a solid full Blu-Ray ISO player with Java menu control that we had a production run of the Smart D1 units scheduled for the USA. This Smart series resurrection will only be on the D1 units, and that decision was based entirely on popularity. This production run is in process as we speak, and the units expected ship date should be the end of this month. Along with the D1 production run we were also able to schedule a small amount of HD Max players. The quantity of Max units are somewhat limited, but we felt we need to have some optical player coverage as well. I hope this clears things up for the moment.
If you are looking for a Smart or Max unit right now, check your local Microcenter stores online. They might still have inventory of some of these units, and I know quite a few people have picked them up locally.
Mike from DunePlayer
