AVS › AVS Forum › News Forum › Community News & Polls › Have You Heard Exotic Audio Cables Improve Sound Quality?
Have You Heard Exotic Audio Cables Improve Sound Quality? - Page 22
Poll Results: Have You Heard Exotic Audio Cables Improve Sound Quality?
  • 8% (45)
    Yes, and it was a big improvement
  • 10% (56)
    Yes, but it was only a slight improvement
  • 54% (284)
    No, I did not hear any improvement
  • 25% (132)
    I don't have enough experience to say
517 Total Votes
post #631 of 645
Originally Posted by olyteddy View Post
And what's wrong with that?
Capacitance.
post #632 of 645
Capacitance.
Just what do you mean by that? CAT5 is 15 picofarads a foot. (http://www.smarthomeusa.com/ShopByManufacturer/Genesis/Item/WG-4978210x/)
Speaker wire, well, is even higher:
Originally Posted by http://en.wikipedia.org/wiki/Speaker_wire#Capacitance_and_inductance
Ordinary lamp cord has a capacitance of 10–20 pF per foot, plus a few picofarads of stray capacitance, so a 50 foot run (100 total feet of conductor) will have less than 1% capacitive loss in the audible range. Some premium speaker cables have higher capacitance in order to have lower inductance; 100–300 pF is typical, in which case the capacitive loss will exceed 1% for runs longer than about 5 feet (10 feet of conductor).
post #633 of 645
15pF per pair. Start paralleling conductors and cables and it goes up very quickly and it can affect the stability of some SS amps, causing oscillation, overheating and in some cases damage to the amplifier (and maybe speakers). It would be pretty much instant death to Naim amps for example. This is a well known phenomenum to those of us who study amp design and I have actually seen a couple of examples in testing on my own bench and repaired severel more from audiophiles who simply read an article on doing this online and tried it to the detriment of their amps.
post #634 of 645
That sounds more like an amp problem than a cable problem.
post #635 of 645
Originally Posted by Jinjuku View Post
Ok here is a quote from the AQ website on the Ethernet cables: DIRECTIONALITY: All audio cables are directional. The correct direction is determined by listening to every batch of metal conductors used in every AudioQuest audio cable. Arrows are clearly marked on the connectors to ensure superior sound quality. For best results have the arrow pointing in the direction of the flow of music. For example, NAS to Router, Router to Network Player. It's packet data! There are send and receive pairs. It's why Ethernet is a full duplex standard.
They are full of it! Monster does the same and they made a ton of money! I use to be ignorant, and bough some monster cables way back when I started in this expensive hobby. Then the Internet came and I educated myself, reopen my physics books as well smile.gif know I know better, I am just buying marketing smile.gif
Should I just challenge the corporate owner/s of AQ? What utter crap.
YES PLEASE, I would love the hear what he says!
Edited by wse - 9/2/13 at 7:55am
post #636 of 645
If you have a system that's working fine and you swap it out for a highly capacitive cable that then causes damage, then it's a user problem. It's difficult for a designer to ensure stability into every load, especially when there are tight margins and low profits to be made. Especially just to sate the whims of a few foolish audiophiles.
post #637 of 645
It's a user problem. When you have engineering teams with 100's of years of man hour experience designing amps they design to common standards and mantra's that hold true in the world of physics. They design and engineer accordingly.
Then you get some person that thinks they know 'better' then the hilarity ensues.
post #638 of 645
And what's wrong with that? 4 24 gauge strands in parallel is roughly equivalent to a 17.5 gauge wire and if you run two pieces that doubles the ampacity to a nearly 15 gauge wire! eek.gif Don't believe me? There's a chart on this page: http://www.powerstream.com/Wire_Size.htm
It doesn't matter if it makes sense or not - my attempt at humor was Audioquest found a market for it, but terminated it with RJ45 instead of speaker connectors.
post #639 of 645
The real fun part is some one takes this stuff serious and others must be keeping Audioquest in business.
post #640 of 645
Well just sayin', BUT a lot of expensive speaker cables have much higher than 65pf per foot capacitance. It's the necessary trade off if you want to keep inductance down. Take a look at the table at the bottom of this article: http://diyaudioprojects.com/Power/Low-Inductance-DIY-Speaker-Cables/
post #641 of 645
Originally Posted by Scott Wilkinson View Post
This is one of the most hotly contested debates in all of audiophilia. Manufacturers make extravagant claims about how different materials and geometries affect the sound—and they charge extravagant prices for these innovations.
Pictured here is a cross section of the Stealth Audio Dream V10 speaker cable, which lists for $14,000 for a pair of 2.5-meter lengths.
Are such high prices justified? Have you heard exotic/expensive cables improve the sound quality of an audio system? What were the circumstances that led to your conclusion?
What a farce! Here is an other one: http://www.morrowaudio.com/
pathetic! By the way their cables are rebadged MOGAMI
post #642 of 645
Are you 100% sure?
post #643 of 645
Originally Posted by audiofan1 View Post
Are you 100% sure?
Close http://www.mogamicable.com/category/products/gold-RCA-RCA_6_12.php
post #644 of 645
Checked them out, and the most interesting thing found is a brown 20 AMP receptacle from Hubbell for 13 bucks. Had not seen the name before and googled that and part # and found this, http://www.hubbell-wiring.com
Its well built? very expensive stuff that only well be used if what?????? $13 was the cheapest price I found, must be counterfeit.
post #645 of 645
??? nothing on the link you provided is solid core silver plated, or did I miss something! perhaps you could be a little more specific.
  Back to Forum: Community News & Polls
