I figure until I actually get the drivers I will keep this as unofficial.
I am getting ready to build my cabs though so everything is ready to go when the drivers finally show up.
That being said, I want to make sure I've made the right decision on parts and some input on cab design and such.
_______________________________________________________________________________________________________________________________________________
We'll start with room layout.
1) Room is on the smallish side: 128" wide x 276" long x 102" high
A) First row of seating is 12' with second row at 17' (first row is 37 degree angle to center of outside drivers with second row at 26 degrees).
2) LFE will be handled by 6 sealed SI drivers.
3) Parts I've picked out.
A) AE TD15M driver
B) BMS 4550 CD
C) SEOS 12 waveguide
I'm planning on crossing this over at between 50-80hz. I'm kind of torn on this so far. I'm thinking the midbass on the TD's might be better than the SI's so a 50hz xover might be in order. Then again, I've always been content with an 80 hz crossover.
If going with an 80hz crossover, I'm thinking a 3cf sealed enclosure would work perfectly. That gives a -3 db point right at 80hz. I'm thinking this would blend nicely with my sealed SI's? I have plenty of room behind my screen so ported is certainly a viable option as well. I'm also thinking about going really crazy and building a separate chamber in the bottom and mounting a sealed SI 15 in each one firing outward to further smooth out room nodes, but this is for another time.
I'm a little nervous on the TD15 and SEOS12 however. The SEOS needs to be crossed above 950, and John recommends crossing the TD15 no higher than 1k. Is this going to leave enough room to blend together nicely? Due to my narrower angle I'm assuming I could get away with a higher crossover, say around 1.2k? Would the TD12M have been a better choice with the SEOS12 and 4550?
I had the chance of listening to a set of current JTR 888's and really like them. I'm really hoping this will trump that setup by a fair margin. I will start building cabs in the next few days so I'll start posting some pics of the progress.
Let the input begin.
I am getting ready to build my cabs though so everything is ready to go when the drivers finally show up.That being said, I want to make sure I've made the right decision on parts and some input on cab design and such.
A) AE TD15M driver
B) BMS 4550 CD
Axiomites everywhere are taking up arms over that statement. I'm just hoping my Axiom surrounds and rear can keep up with the front stage now.
