Those shelves look great for vinyl. but please be careful!
1. they are not made of the best materials
2. since the shelving systems do not have a rear wall/support- you are hoping that silly hardware will work. but without good wood, the hw will not be good enough. the wood will break and the shelves will fail.
3. if you have a ton of weight on it, and it's not boxed in, with other shelves literally touching the vinyl shelf on both the L + R side, or a wall... anything super-solid/heavy to support the sides, it will fail.
Please remove the albums, and drill some strong L brackets into all corners.
And if you have your hifi gear right next to the shelves, and they are not supported, move that hifi gear!
Feel bad, but I've been collecting images of epic fails.
Fail by fail, on Flickr
Expedit Fail by fail, on Flickr
FAIL by fail, on Flickr
