Originally Posted by
Mfusick
By formatting you mean in windows ?
Did you format the motherboard ones different ?
MBR ? GDP? Quick ? FULL ?
I'm not understanding. It takes me 15 seconds to format a 3TB drive.
I activated all 10 drives as GPT and did a full format @ 64k clusters via disk management. It took about 6 hours on the drives connected to the M1015, and took over 12 hours for the 2 connected directly to the motherboard. Crazy that both 6g systems were so different, I wonder what the 6g Marvell controller would have done? I used identical settings for all of them, and verified again that the mobo ports I plugged into were the x79 native 6g ports.
The extra bandwidth of having 40pcie lanes to the processor is the only thing I can think of that would have caused the card to operate so much faster than the motherboard native connections. All drives show 6g and correct attributes, so it's not a bad connection.
Mfusick
Just use the ASUS auto overclock software.
You can set it up so only your turbo boost is high clocked. Say 4.3ghz. But when not needed your CPU can cruise around at 1,6ghz and save energy when not needed.
I'm a bios overclocker by nature. I got it stable at an offset of +.020 @ 4.3GHz for a full load voltage of 1.32v and max temp of 74c. I took manual control of all the voltages on the board because some people reported asus likes to pump vccsa and vtt pll up over 1.2v on auto which will kill a c2 stepping 3930k in hours.
I was also able to tighten the memory from 11-11-11-30 3t @ 1.5v 2133MHz to 9-9-9-24 1t @ 1.5v 1600MHz. Significant boost there for SB-e.
So at idle I run at around 1.2GHz at .88v and under max load and heat I hit 4.3GHz @ 1.324v. I couldn't get stable over 4.3 without adding more than 1.35v so I stopped there to cut on heat and power use. All c states and whatnot still enabled so I don't burn juice.
I also installed syncbackpro to back up data from the other pc's in the house to the server, and Hard Disk Sentinel pro so I could get real time SMART monitoring of all the drives connected to the M1015. Diskeeper12 Pro is running my defrag and drive optimization functions.
I did kill virtualization, but I should be able to turn it back on I anything I install from here out needs it.
Edited by goros - 3/11/13 at 12:17pm
