AVS › AVS Forum › A/V Control & Automation › Home Automation › Crestron gui
Crestron gui
post #1 of 13
Hi all...i'm searching for a crestron template to use in my projects...i've tried to contact ntdesing three/four times but with no response....i should have to try with guifx...any of you did ever use them? May i have any your suggestions? Thanks a lot...
post #2 of 13
My knowledge of Crestron is very limited, but this may be of help to you...
http://www.customcodecrafters.com/
post #3 of 13
You may wish to look at www.guijaboard.com, the Tactical template is beautiful, clean and very flexible. It also addresses the limitations of many templates, which is what do you do when you need to customize it for a component that is not part of the stock template? To address that, it comes with a huge amount of graphics, with hundreds of different button sizes etc, so you can also easily create your own pages as well. Full disclosure, the owner of Guijaboard works for my company (but Guijaboard is his, I have nothing to do with it).
post #4 of 13
Hi David...i know guijaboard...before this thread i went around on web looking many "gui interfaces"....but honestly, i found ntdesigns the best in graphic...so i've decided to purchase a crestron template and i asked informations for products, payment and downloading.....but no response, no answer, nothing....So i thought to get any suggestions from you...I hope this Guijiaboard might be more serious than others....
post #5 of 13
I remember your post at the remote central gui forum a while back. I just got your PM there and i responded to you. Just repeating this information here so that others don't think NTDesigns is offline.
My guess is that there is some sort of problem with the contact form at NTDesigns. Try their email address or facebook page. info@ntdesignsonline.com https://www.facebook.com/ilikent
While you wait for a response... What questions do you have for NTDesigns about their templates? I may be able to answer them for you. I am familiar with some of their products.
post #6 of 13
This is the best advice i have ever seen posted at any forum on the internet about any subject ever biggrin.gif.
post #7 of 13
Were you able to get anything from GUIFX? for iPad?
post #8 of 13
Here we go.
post #9 of 13
Might as well add that if Crestron follows up with fully implementing Core 3 UI all existing templates will be unusable on any panels which require Core 3 UI interfaces.
I have spent days in Photoshop over the last couple of weeks to get some usable graphics and panels going for Core 3 UI.
post #10 of 13
NT Designs responded as soon as I contacted them so you may want to try, again. GUIFX, on the other hand, hasn't returned calls, emails, Facebook etc. I really think they have some of the most outstanding graphics available anywhere. Unfortunately, they're also very pricey.
post #11 of 13
Just heard from Morgan. Guess he was out of town. So all's good.
post #12 of 13
I found a Dealer for all i would need in graphic...but backgrounds, icons and theme styles are usable in both existing panels and Core3....i've just installed a tsw-750 panel and for each button, i set an image used in the normal projects...Probably for smart objects only you must use Core3 graphic, but for the rest it remains the same.
post #13 of 13
there is also Blackman signature designs
http://www.blackmancustoms.com/
We have used a few of his templates for RTI and Crestron
Guijaboard is also a great company to get Graphics from
  Back to Forum: Home Automation
