AVS › AVS Forum › Video Components › Home Theater Computers › Assassin's Intel NUC Review
Assassin's Intel NUC Review - Page 4
post #91 of 578
This thing is a wonderful "thin client" HTPC and a perfect complement to my central file server. Who needs underpowered and limited smart TVs with this ?
It also has very high WAF wink.gif but that part was easy as it replaced a mid-tower tongue.gif
I have bought the Ethernet core-i3 version (DC3217IYE) and complemented it with:
  • Fast low latency DRAM (DDR3-1600 CAS Latency 9) Corsair Vengeance 8GB DDR3 1600MHz SODIMM Kit (2 x 4GB). Remember that both CPU and GPU will benefit from low latency 1600MHz operation !
  • Fast mSata SSD (Plextor PX-128M5M 128GB SSD Jedec MO-300 mSATA Marvell Controller). Speed is not an issue here, but at the same price, might as well be fast !
  • Logitech K400 keyboard-touchpad combo
On the firmware/software, I immediately applied latest BIOS and SSD firmware.
It was built Friday March 15th with :
  • BIOS 039
  • latest firmware (1.02) for the Plextor SSD (came with 1.01)
  • latest drivers from Intel site (I almost never use the drivers CD coming with new hardware)
  • Windows 8 Pro
Running JRiver Media Center 18, I was able to play the jelly fish test MKVs (http://jell.yfish.us/) through the network without stuttering at up to 100Mbps, from a Synology DS211 dual drive NAS box. Only the 110 and 120Mbps sample MKV showed stuttering. I have a wired Gigabit Ethernet network.
I also played Blu-Ray ISO rips perfectly from my main ISO file server (a Linux box running Samba), again using JRiver Media Center.
However, 3D is not on the radar screen for me, so I cannot offer advice.
Cheers !
Edited by RudyRedNose - 3/19/13 at 6:07am
post #92 of 578
Following up on my NUC adventure
Overall very impressed.
I have the i3 version with a 32 G ssd installed and 8G RAM
Running a "custom" openelec build (that fixes a black crush issue).
This thing boots up in like 5 seconds straight to XBMC. Way faster than even my PS3
No issues so far with HD audio playing BD bit rates.
Got the Ortek remote from amazon and connected the IR USB receiver. No issues with using my harmony remote
post #93 of 578
Are you able to do live tv with openelec and an hdhr prime?
post #94 of 578
So how would I go about getting this as a htpc and also emulator using a wireless Xbox controller? Here what I know I need.
Ram
Ssd
Power cable
Windows
Here's what I am unsure about. How to use my harmony one remote with this? Just a USB ir receiver plugged right in?
Also, how to get it to respond to xbox controller commands? Another USB attachment?
post #95 of 578
You need the wireless adapter for the xbox controller.
www.amazon.com/Xbox-360-Wireless-Gaming-Receiver-Windows/dp/B000HZFCT2
post #96 of 578
Thank you.
Is anyone that is using this for an HTPC not happy with the results?? Why?
post #97 of 578
Originally Posted by Popeeta View Post
Thank you.
I'm using this one on my HTPC for numerous emulators and it works perfectly. Check the comments for how to install the drivers properly. XBMC 12.0 supports the Xbox 360 controller as well.
post #98 of 578
Thank you.
Using the NUC also?
Also, are any of you just using a remote control to use windows/xmbc setup or are you needing a keyboard and/or a mouse? Thanks guys
Edited by Popeeta - 3/26/13 at 6:54pm
post #99 of 578
Using the NUC also?
Not using the NUC, but it's a basic USB device and should work fine.
post #100 of 578
I stripped one my screws that hooks onto the VESA mount. Intel kindly shipped me a new one free of charge and just received it now. Here is a photo on how I mounted my nuc behind the tv.
Two screws into studs and the left side is being held with drywall anchors. Its very sturdy, you would have to hang on it to rip it down.
post #101 of 578
I have had my i3 with gigabit ethernet NUC for around 2 months. Great system. I run win8, xbmc 12.1 with 4gigs ram and an internal 64gig Kingston mSATA(ssd). It is almost perfect. Unfortunately recently I started hearing the fan occasionally. Whiny. It comes and goes. I will have to find a fanless case if the noise doesn't depart.Might be a defective fan or some other reason but I hear it off and on from 8 feet, whereas it was silent for over a month. Discouraging actually.
philip
post #102 of 578
Check your cpu temp. Have you tried cleaning out the heatsink with compressed air?
If that doesnt work then contact intel, they have great customer support. The fan could be defective, who knows...
post #103 of 578
Using the NUC also?
For xbmc I only use my Harmony One. I can't seem to use Netflix under windows 8 with only a remote. Same with Hulu Plus. But for XBMC or Plex an MCE remote works great. I can start and quit XBMC or Plex, wake up, sleep, get to the start menu/tiles with the remote. I also have a Lenovo Multimedia remote for the things I can't do with the Harmony ( like typing this wink.gif ).
philip
post #104 of 578
The latest BIOS 040 fixed the LAN issue so now I'm able to use the HDMI port closest to the Ethernet port.
post #105 of 578
So to make a HTPC you need a USB IR receiver for the remote, a USB TV tuner and USB or LAN HDD storage?
If they make one large enough to fit a HDD in I'll be sold.
post #106 of 578
I think the next version will have USB 3.0 so you could velcro a external HDD to the case tongue.gif
post #107 of 578
When I was searching for the latest bios I ran across this new SKU DC53427HYE under products codes. Wonder what it is. All of Intel pages say not found. Anyone have any insight on DC53427HYE?
post #108 of 578
Searching for it, I found mention of "triple display" here: http://www.builderdepot.com/browse.ihtml?step=5&prodstoreid=12154&pid=1694966. Makes me think it might be the core i5 version, as referenced here: http://techreport.com/news/24178/new-cheaper-intel-nuc-coming-next-month
That is, assuming current models do not support triple displays. I do not know if they do.
post #109 of 578
Yeah it sounds that way, and from the number sounds like it would be using the Core i5-3427U
As for the triple display, from this YT video it's using 1 display via HDMI and 2 displays from Thunderbolt/Display port (daisy chained, I'm guessing). So technically the Thunderbolt version of the i3 NUC could support 3 monitors as well, though maybe not as well.
Edited by boournz - 4/8/13 at 10:22am
post #110 of 578
You can use a networked tuner like the SiliconDust HDHomeRun models instead of a USB tuner.
post #111 of 578
post #112 of 578
Yup. Crucial also just popped out some new mSATA drives so things are looking might great for anyone looking to buy a NUC. I'm waiting for the Haswell NUCs myself.
post #113 of 578
Assassin says that he gets 23.973 fps out of his Nuc. However in the thread on the xbmc forums everyone is saying that it does not work at that frame rate. Hence why you get dropped frames and pauses when running bitstream audio because the video and audio are not in sync. It was suggested the nuc is running at 24 fps and as such every few mins you would lose a couple of frames in order to keep the audio working.
Does anyone here have any thoughts on this? I appreciate that this is only when Bitstreaming and that when it is just DTS or DD then 23.973 is fine.
Edited by churchwa - 4/9/13 at 1:45pm
post #114 of 578
I could never get 23.976 to work with or without h/w acceleration turned on
I have settled with 60Hz o/p
Whenever I would try to turn on "match rate to source" to force 23.976 o/p, i get audio sync issues
This is with XBMC running in windows 7 and openelec
post #115 of 578
Deal breaker for me...
Will hold on until this gets sorted out...
post #116 of 578
I posted screenshots of xbmc playback. Tried mpc-hc as well.
post #117 of 578
post #118 of 578
A 65w TDP chip inside a NUC form factor? I doubt it.
post #119 of 578
It could happen. Remember that TDP numbers are not real-world numbers. You can have a chip with a 65w TDP and have it draw a third as much power under normal use, which could work well in a NUC and chips like that have already been tested with NUC designs and found to be acceptable by several companies.
post #120 of 578
I would think the Haswell NUC would use the ULV variant just like the Ivy Bridge NUC uses the ULV variant. Being someone who builds a lot of mini-ITX machines, 65W TDP would be too much heat (TDP is a measure of heat) for such a small case. Even 35W would be too much.
I hope the -R variant motherboards are thin mini-ITX. That would be awesome.
