Hello guys, not sure if this is the correct location for this.
I bought this projector 2nd hand. It only has about 300hrs on it in total.
My setup only has a lightning surge protector on it for the power. It is not on a UPS.
I don't eve have a screen yet and have only had it about two months.
It is connected using a 15m HDMI cable (cheapie)
Twice now we have had lightning that has been closeish but not a direct strike. More a flash with a loud thump and the windows rattle.But possibly with some sort or pressure wave or static charge ?
But basically twice when the unit has been in standy it seems to have blown the hdmi port.
First time I simply plugged into the additional hdmi port and carried on working.
This time no luck as it already had one blown.
Is this common ? I understand when you take a direct or fairly direct strike but this was not exactly on my door step.I was very surprised todays strike was able to affect it.
Can it be repaired and what can I do to try and prevent this in the future ?
I just want to make sure I'm not being had.
