Hi, I have a digital receiver system.
Current I have my PC, cable box and Xbox connected by digital optical cables.
But i only have one digital optical input so have to connect them through a manual switcher.
So firstly i'd like a system that could take all these separate connections. Then I could switch between on the remote.
But I would also like to be able to play out more than one of these inputs at the same time.
For instance, play on the Xbox while also listening to some music playing from my PC.
Anyone know if there any systems that can do this - play audio from multiple sources at the same time?
