AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Zone 2
Zone 2
post #1 of 6
I have read manuals and looked on this forum but I have failed to find how to turn on zone 2 or 3.
Could someone please explain in detain how to assign zone 2 output to an external amp.
This is for the 3312ca. thanks in advance
post #2 of 6
Plug in the stereo analog cables into the Zone 2 pre-outs on the 3312CI and into the external amp. Then set Zone 2 to ON and select the non-HDMI source audio to play to Zone 2.
http://www.avsforum.com/t/1334369/the-official-denon-avr-xx12-model-owners-thread#user_M
Also note there is a dedicated thread for Denon AVR-XX12 Owner's linked in my sig. Review posts #3-6 in that thread for additional helpful information.
post #3 of 6
Ok, so just an update on trying to get my zone 2 to work.
I have a 3312 with the zone 2 turned on, I am using the USB as the source.
I have the RCA connected to the zone 2 pre outs to an external amp. I have the speakers connected to the external amp with new wire. and still I am not able to get any sound to speakers, but here is the kicker.....I am getting sound out of the surround rears, as I normally use the system as a 7.1 in my main listening area.
Why will my zone 2 not work properly?
I appreciate the help I have received from the knowledgeable people here.
post #4 of 6
So then with AMP ASSIGN set to Zone 2 the USB audio is heard from the Surr Back/Amp Assign speakers, yes? Visually confirm the RCA cables are plugged in to the Zone 2 (and not Zone 3) pre-outs as noted below. Also make sure the external amp is powerd ON as well. If all previous is confirmed, then swap the Zone 2 speakers with the Surr Back speakers to ensure they (as well as the Zone 2 pre-outs) work properly.
post #5 of 6
Thanks JDSmoothie, Yes I have confirmed that the RCA cables are indeed connected to the Zone 2 preouts. the amp is defiantly powered on. and yes I have made sure Zone 2 speakers are connected and working. I actually did connect to surround backs.
For shits and giggles I swapped RCA to Zone 3 and turned on zone 3 and it was the same. only sound to the surround backs...
I did not think this was going to be this complicated Thanks
post #6 of 6
If the source selected for Zone 2 is playing to the Surr Back speakers with Amp Assign set to Zone 2, then there's no reason the same audio shouldn't also be playing to the Zone 2 pre-outs. Try unplugging the AVR for a few minutes and if still no joy then a microprocessor reset would be your next step, noting you'll want to SAVE the config file to a PC using the Web Control feature (pp. 80-81)first to more easily return to your original confiuration. Also note the following ...
http://www.avsforum.com/t/1334369/the-official-denon-avr-xx12-model-owners-thread/0_100#user_E10
