Hello. I recently purchased a Samsung HW-E450C soundboard and am tring to connect it to a Sony Bravia HX850 TV and an LG BP620C blu-ray player. Yes, I understand that I broke the cardinal in of trying to link different brands, but I have good reasons for doing so. I tried linking the three through HDMI cables, but then I couldn't get the blu-ray player to run. Is my only other option connecting the blu-ray player to the sound bar via digital optical cable, the blu-ray player to the TV via HDMI, and the sound bar to the TV via two-to-one stereo male RCA cable? I recently moved to Venezuela for work and want to make that I get all necessary cables to get everything to work. Thanks for your help.
Featured Stories
Topics Discussed
Related Forum Threads
- BP620C new LG 3D player Last post on 11/19/12 at 12:19pm in Blu-ray Players
- LG BP620 or Panasonic DMP BDT 220/320, or other? Last post on 9/23/12 at 6:30am in Blu-ray Players
Help connecting Samsung HW-E450C to Sony TV and LG BP620C blu-ray player
Gear mentioned in this thread:
post #2 of 4
3/1/13 at 9:16pm
- Doctego
- Trader Feedback: 0
- offline
- 552 Posts. Joined 11/2012
- Select All Posts By This User
Is the BD player the only source? If so, you can just connect the BD player to the HDMI IN on the soundbar and then connect HDMI OUT on the soundbar to the TV. I don't know what you mean by you "couldn't get the BD player to run". You should be fine connecting it as I described and changing the SAT SOURCE to HDMI on the soundbar. If you have other sources, you need to let us know.
Well, ideally I would like to connect a Roku device, the blu-ray player, a PlayStation 3, and the soundbar together, but I figured I would initially test it with the blu-ray. I do have an HDMI hub with five input ports and one output port, if that helps.
I did try the setup you described. I hat the soundbar plugged into the HDMI 1 port on the TV and had a second HDMI cable running to the sound bar (yes, I made sure I had the cables plugged into the correct ports on the soundbar) from the blu-ray player, but when I set the TV input to HDMI 1, the TV didn't register a connection to the blu-ray player. It could not detect a device there and there was no audio or video. I also made sure to have "HDMI" selected as the source on the soundbar, but still nothing came through.
Any thoughts on what I am doing wrong? Unfortunately, I don't have cable TV here to allow testing of the soundbar on its own with the TV, though the soundbar does connect to my iPad via Bluetooth, so I know it works.
Thanks again.
Thanks again.
post #4 of 4
3/2/13 at 5:44am
- Doctego
- offline
Thanks again.
Thanks again.
If by HDMI "hub", you mean switch, that's exactly how I have mine connected. Cable DVR, BD player, XBox 360 Kinect, and Roku are all connected to the switch, the switch goes to the HDMI IN on the soundbar, and the HDMI OUT on the soundbar goes to the TV. I would start simple and move to more complex reasons. Double check your connections. Make sure that the SAT SOURCE is set to and stays at HDMI. This soundbar has a habit of switching back to D.IN. Do you have any other HDMI cables to try? High-speed cables are always recommended although I'm not sure that would matter assuming that you have short runs. I would also try connecting to a different HDMI port on your TV.
- Help connecting Samsung HW-E450C to Sony TV and LG BP620C blu-ray player
Currently, there are 1119 Active Users
(190 Members and 929 Guests)
Recent Discussions
- › The BMS group buy thread!!! 21 seconds ago
- › Official OPPO BDP-103 Owner's Thread 42 seconds ago
- › Buzzing sound and extreme dithering grain on S60-series (2013)... 2 minutes ago
- › Pivos AIOS HD Media Center: The *Semiofficial* Thread 4 minutes ago
- › Samsung PN60E530 Owners Thread 5 minutes ago
- › Will you head back to the consoles, or double down on PC gaming ? ... 6 minutes ago
- › Sherwood R-972 User Thread 12 minutes ago
- › Official Panasonic VT60/VT65 Series Discussion Thread [No Street... 13 minutes ago
- › recommendations for a subwoofer that pairs well with Polk LSiM703... 13 minutes ago
- › The **OFFICIAL** Denon AVR-XX13 Model Owner's Thread & FAQ 14 minutes ago
View: New Posts | All Discussions
Recent Reviews
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › BenQ W1070 1080P 3D Projector by jakob_s
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
- › Epson 5020UB Powerlite Home Cinema 3D Front Projector by DDT0C
- › Sony VPLHS20 Cineza Digital Home Entertainment LCD Projector by varkeast
- › JVC DLA-RS45 Home Theater Projector 1080P HDMI by jmccarei
- › Sharp DT 510 DLP Projector by rdcollns
- › Onkyo TXNR801 / TX-NR801 / TX-NR801 7.1 Channel Digital Home... by mswope63
View: More Reviews
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
View: New Articles | All Articles
Home | Reviews | Forums | Articles | My Profile
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
