AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Optoma HD131X : Cheaper black version of the Optoma HD25
Optoma HD131X : Cheaper black version of the Optoma HD25 - Page 2
post #31 of 41
Originally Posted by kraine View Post
I prefer the RF 3D picture thanks to the contrast. With DLP-LINK the white or red synchronisation flash is disturbing.
Great, thanks for your help.
post #32 of 41
post #33 of 41
Kraine, thanks for the review.
Are there special settings for 3d mode (color calibration) or it is the same as the 2d?
I see now that on your site, you give this projector 4 stars while the benq w1070 you give 4.5 stars, do you consider the benq as a better projector, if not can you explain the higher score?
Edited by gofmarat - 3/15/13 at 10:49am
post #34 of 41
I have bought the HD131X for my own, it's not only a presssample model, so I made my choice wink.gif
Hello.I wanted to know your thoughts on the flickering issues or problems with the optoma HD25 or HD131 since it doesn't have any triple flash 144hz or image interpolations. I'm thinking of getting one mostly for 3D.I'm stuck between these models or the Benq w1500 which has triple flash and interpolation but deals with dlp link only for 3D.I know how much you recommend the RF for 3D.so I would appreciate your opinion and thoughts.
post #35 of 41
In my Opinion the HD25 and the HD131X are also tripleflash compatible, like the W1070 120hz DLP LINK 3D Glasses aren't working, only 144hz Glasse are compatible.
The BenQ W1070 has better score because out of the box the colors are more accurate and he is also quieter than the HD25/HD131X.
post #36 of 41
Originally Posted by gofmarat View Post
Kraine,
post #37 of 41
I'm using factory 3D settings, I didn't calibrate the 3D picture, only the 2D.
post #38 of 41
so flickering is not a problem with the HD25 or HD131X.
thanks for your input and it seems that the RF glasses gives the Optoma an edge for 3D which is what i'll be using the projector mostly for.
post #39 of 41
any updates?
post #40 of 41
I'll be receiving it around the 4th of April. I'll update as soon as it arrives
post #41 of 41
You must like it enough to own it. Is it better than the Benq W1070? Thanks
