AVS › AVS Forum › Audio › Speakers › Crossovers - Most Likely Component to Fail
post #1 of 3
Hi, new to this to - be patient!
One of my Celestion F30's has lost mid-range, by substitution I have worked out that the problem lies in the cross-over, which has just 5 components, 3 coils and two caps, a 9uf 50v and a 10uf 100v which bridges the MF output.
My question is would the most likely failure be one of the caps? and could I replace the 9uf with a 10uf?
I'm guessing the coils would be almost impossible to replace (.85mh & 6mh)
Thanks for any help.
post #2 of 3
Originally Posted by keicar View Post
One of my Celestion F30's has lost mid-range,.
This explains how crossovers work:
http://www.bcae1.com/xoorder.htm
post #3 of 3
How do set crossover for the center channel
  Back to Forum: Speakers
