AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › BD590 won't play bluray & also won't downgrade - help?
post #1 of 3
My BD590 said "upgrade available" so I allowed it to network-upgrade to what turns out to be BD8.97.423 / H90378 / H09LGN.
Now it won't play BluRay discs at all - every one that goes in results in a disc error.
I have downloaded alternate firmware and tried to downgrade but the player is not recognizing the downgrade. Can someone give a hint what I'm doing wrong? Here's what I've tried:
1. Downloaded a .ROM.zip file which unzipped to a .ROM folder with .ROM-00 and .ROM-01 files inside
2. I tried putting the folder (with two files inside) onto a flash drive and inserted into system. The system did not say anything about upgrading.
3. So I tried taking the two files out of the folder and putting the two individual files in home directory of the flash drive. Same result.
4. Then I tried putting the two individual files into the home directory of a CDROM and inserting that. Same result.
5. I unplugged and plugged back in.
6. I used the "initialize" command on the setup screen.
7. Still same results.
BTW I am using an iMac to write to the Flash and also to burn the CDROM. Don't see why that would make a difference but just in case.
Any clues on how to make the player recognize the downgrade image?
Also: does anyone else have experience with this new .423 image? I tried 4 bluray discs on it and all ejected without reading. It actually works fine for Netflix streaming and for DVD but not for Bluray at all.
help?!
thanks
post #2 of 3
Hit the post reply button inside the owner's thread. Not start a new thread.
S~
post #3 of 3
S~
Best idea since most of the guys are subscribed to that thread and won't even see this one. Thanks.
Thread closed.
This thread is locked
