AVS › AVS Forum › Audio › Receivers, Amps, and Processors › HELP! Denon Avr 888 Suddenly no sound zone 1
post #1 of 6
HI All!
Im fairly new here and not sure what the heck is going on with my denon 888. Its been working fine for a couple years, All of the sudden I turn on the TV/power and i hear a loud muffled sound come through the speakers...then nothing but silence. I just turned it off, then when my husband came home he turned it on and it worked? (No jokes please tongue.gif) After several hours it stopped working again for HIM. I figured it just sort of "blew up" BUT Zone 2 in my kitchen works fine. Any Ideas or are we just screwed?:eek
post #2 of 6
try spraying some compressed air in the headphone jack. It might seem silly but I've seen it work.
post #3 of 6
Ok..had fingers crossed but this didnt work ..thanks for the tip anyway!!! I also sprayed the top vents and plug connections with air.
post #4 of 6
What does the front panel of the 888 display when there is no audio heard? If it says something like "H/P ON" then you'll need to blow more compressed air into the headphone jack (or insert/remove a headphone plug a few times) otherwise if not, you may want to try resetting the microprocessor (p. 49 OM) which will return all settings to factory defaults.
post #5 of 6
Thanks! So far the factory reset is working..fingers crossed!
post #6 of 6
