Ok, so here is subs only no speakers for the last time, from now on I'm going to run speakers too. I just wanted to compare how much spl gain I get with using the same volume settings just adding subs.
Obviously the top red line is all 8 subs.
Still can't figure out why my snapshots are changing the db increments to 10, they are 5 when I measure and on my saved files.
Well, it looks like I would have guessed other than from 100-200 hz, massive gains there. Could that be because if the height? All 3 sweeps were done with 200hz crossover on the receiver.
You're still in a good spot though. When will you think you'll have the MDSP installed?
