Went ahead and picked up a P50S60 at my local BestBuy. Calibrated it with my i1Display2 LT and colorHCFR using the AVS HD 709 disc. Had a bit of trouble tuning in the settings, not sure if it's my meter having issues or what. Will do another calibration after 100 hours and will possibly pick up a ColorMunki at some point. Here are the settings I came up with:
custom
contrast 83
brightness -2
color 44
tint 0
sharp 0
warm 2
vivid color off
cats off
video nr off
mpeg nr off
pro settings
panel brightness low
agc 0
black ext 0
color gamut normal
w/b detail adj
w/b high r -10
w/b high g 0
w/b high b 12
w/b low r 6
w/b low g 0
w/b low b -10
color detail
all default except for
green lum -10
blue lum -5
gamma 2.4
1080p pixel direct off
hdmi content type default
hdmi/dvi rgb range standard
black level light
Above settings give me an average gamma of 2.34 with de's for grayscale ranging from 2.3 to 9.3 (I obtained a much better calibration aside from horrible gamma of 1.9 for my P42S2, all de's under 3 and some under 1), and my color de's are ranging from 5.1 to 10.2 for both primary and secondaries. I calibrated using large APL patterns for both grayscale and colors, and I used 75% color patterns.
Also I have 31 ftl with this contrast level.
